RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 676
fulltimin
Home is where we Park It.
Posted: 09/14/20 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
Then, it was time to step on the (doo-hickey), while on the scale.
The first part shows a little over 240 lbs.
The second shows about 345 lbs.
That was a trip trying to balance on one foot, on a board with only 1 screw on each side, (can u say - not stable), all while trying to take a picture. Lol.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 09/14/20 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
So, the 2 x 3's didn't collapse in the center. By the way, the 2 screws in the bottom were just screwed in from the side, and I did not use the Kreg jig to drill pocket holes.
What's the point of all this?
Well, according to a question the other night about weight being supported by 24 screws.......
And that set my mind a runnin'..........
So, a preliminary conclusion would amount to - if I wanted to push this a little, 330 lbs divided by 2 = 165 lbs of weight being held per screw on the outside.
That would mean, 165 * 24 = 3960 lbs for those 24 screws. I would think that putting 600 lbs on that scaffold would be safe, since we have the equivalent of 3360 lbs of excess holding ability.
But, alas, I digress. Do NOT do this at home, based on what you read here. Do your own research, make your own decisions, based on your research, not mine. Ok? Ok.
That isn't the only test I plan on doing, so hopefully within a few days, I can get the other one done as well.
Thanks for the question, Pastor C!
fulltimin
Posted: 09/15/20 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Whatcha gonna do, whatcha gonna do, whatcha gonna do - when ya need to cut a bunch of pieces of 2 x 4's the same length?
Clamp yer miter saw to a secure object, clamp yer stop block to same secure object the correct distance from saw blade, and cut 'em up.
Lather, rinse, and repeat.
Cut one, slide board, cut again, repeat.
I cut my 2 x 4's for the scaffold railing legs today. Yay!
fulltimin
Posted: 09/15/20 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
After cutting a number of them, I decided to secure 'em with Kreg pocket holes and screws.
Next step is to mount jig to, (drum roll), same secure object with a couple of clamps.
fulltimin
Posted: 09/15/20 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
Mount said 2 x 4 into Kreg jig. I lined up the 2 x 4 with the left side of the jig - red arrow.
I then proceeded to drill 2 pocket holes - yellow arrows.
Next is to move the 2 x 4 to the left, and line up the right side with the jig - red arrow again.
Then I proceed to drill through this hole - yellow arrow.
fulltimin
Posted: 09/15/20 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
When done properly, the 3 holes wind up looking like this.
If, on the other hand, you're not paying attention to what you're doing, it ends up looking like this..... Oops....
fulltimin
Posted: 09/15/20 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Today, I added my "Y" bracing on the drivers side - red arrow.
I then proceeded to add the scaffold railing, which is 33 - 1/2 " high. Why 33 - 1/2? Because the 2 x 4's were 16 feet long, and by cutting them 32" long, yielded 6 of them from 1 piece of lumber.
Anything longer or shorter than that, would have resulted in a bunch of wasted wood. Add the 1.5" on top, and we have a railing 33.5 inches high.
fulltimin
Posted: 09/15/20 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
I also added the railing across the back, and I needed to add a short piece of plywood - red arrow - to complete the floor. There was about a 6" gap there, which needed filling.
fulltimin
Posted: 09/15/20 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
And finally, I installed the railing on the passenger side as well.
YeeHaw!
Almost ready to get started on finishing the roof.
Stanfordstander
Penang Malaysia East
Posted: 09/15/20 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
share with us more
Page of 676
