fulltimin
Home is where we Park It.
I also started work on a prototype setup for the rear shelf, which will go beneath the rear window cover.
Let's assume that the window behind the plywood is a wall. My shelf is 1/2" plywood, and as you can see, I routed out a portion so that a piece of 1/8" thick plywood will sit in there and the plywood will still be flush with the wall.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
When the shelf is pulled into the upright position, the hinged piece of 1/8" thick plywood will automatically fall down into this position.
The only hardware needed is a hinge, as gravity will do the rest. When putting the shelf back into the down position, all I need to do is push the 1/8" plywood back up into position, and the 1/2" plywood shelf will fold down easily.
I do plan on using one of these towards each end of the shelf, so between the 2 of them, they should hold the shelf nicely, and out of the way when not in use.
Bill.Satellite
Full-timer
Where does all the equipment required to "put on her face" go when the table is folded down. Sounds like a lot of work to move it to and from the shelf everyday.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
fulltimin
Bill.Satellite wrote: Where does all the equipment required to "put on her face" go when the table is folded down. Sounds like a lot of work to move it to and from the shelf everyday.
That's actually a good question. Currently, almost none of her "put your face on" items are on the counter. Almost everything is in a small cabinet behind a mirror above the sink area.
Using a drawer to the left of where the shelf will be will hold her "stuff". She doesn't use much makeup, so it won't take up much space.
fulltimin
Had a family day yesterday with the son, and it was great. It's always a good time when family visits.
Anywhooooooo.......
Went to the close Lowes store, 3 miles, instead of the 8 miles to the Depot, and looked for hinges.
I ended up buying a pair of these to use with the shelf at the rear of the coach. They are 1 - 1/16" and are 30 inches long. Got 2 of them.
Yes, we are decorated for Valentines day.........
fulltimin
This is what I was confronted with. The 2 with the red arrows were the same width, but different lengths.
The one at the bottom was 12" long, and the one at the top was 30" long.
Prices? $6.48 for 12", and $7.98 for the 30" one. 2.5 times longer for a mere $1.50. Whoda thunk?
Yes, they are identical, except for the length. Same width, same thickness, same finish - everything, including the same manufacturer. Go figure.
fulltimin
![[image]](http://paddleupstream.com/mohorebuild/hinges3.jpg)
fulltimin
I think we may have completed our list of kitchen appliances that are on our "must have" list. This is for fulltiming use.
Our first is a 3 burner cooktop, powered by propane.
We also have a convection oven which doubles as a toaster. There is a newer version of the one we have, which also serves as an oven, a toaster, a dehydrator, and an air fryer. There are about 13 different settings on the upgraded one, and I must say "I want one"!
In addition, we use a microwave frequently for reheating small amounts of food.
We also use an Instant Pot frequently.
We have a small portable blender, used daily, as well as a bread making machine that we use at least twice a week, plus at times making pizza dough, or dough for rolls, buns, or bagels, which get made in the portable electric oven.
We also use a Keurig coffee maker on a daily basis.
Our frying pan is of the non-stick variety, along with a few T304 surgical stainless steel pots for cooking things like pasta and veggies.
Along with that is my newest best friend - a vacuum food saver. I have discovered that most foods actually last muuuuuch longer in a vacuum sealed bag than food that is stored without vacuum packaging. In some cases, food that would have gone bad in 1 month have lasted 4 - 6 months! Yay!
As a result, I have created a few cardboard replicas of some of these items, so I know where and how they will fit.
Wahoo!
Larry202br
Olathe, Ks
Our toaster/oven just bit the dust! Which model did you choose as your favorite?
2006 Open Road 316 RLDS-5
2004 F-250 Diesel, short bed, SRW, Crew cab, 3.73 auto.
RLS7201
Larry202br wrote: Our toaster/oven just bit the dust! Which model did you choose as your favorite?
Hey Larry, stop by Quartzsite and I show you ours.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
