RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 798
fulltimin
Home is where we Park It.
Posted: 01/10/22 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Old Islander wrote:
I had to make a bunch of frames similar to that and found a half-lap joint to work well. If you set up your table saw, you can cut a bunch of them very quickly, in one operation. Run the piece through a number of times, nibbling away the material so the depth and length of the lap are the same on each. A bandsaw works too but requires two set-ups. Assembly with glue and a couple of small brads, and the wood will bust before the joint.
Thanks for the post. Not sure why my brain went blank on this section, but it did.
That's not a joint I normally use, but in this case, I am going to make an excepion.
Thanks.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 01/10/22 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
I managed to get my lumber cut up into pieces that would work for the doors I wanted to build.
I cut all of them at once, since it saves time, and I only have to setup the equipment once.
After I cut the boards to size I setup the router and cut the half lap with it.
Here's the setup, with a fence, and a stop block. The fence holds the door frame from moving away from the router bit, and the stop block prevents the frame from moving too far.
fulltimin
Posted: 01/10/22 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
As you can see making multiple cuts with the router yields an uneven cut at the end of the cut. After moving the fence a few times, these cuts were done, and the uneven section will be cleaned up with the last cut.
fulltimin
Posted: 01/10/22 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
For the last cut, I set the fence to the proper depth, then used a block behind the frame to keep it square, and it made a very small trim cut to finish making the uneven edge straight.
fulltimin
Posted: 01/10/22 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
Then it was a matter of applying glue and clamps, after making sure they are square, and by tomorrow the glue will be cured, and I can make the panel which will fit inside the frame rails.
I have 3 of these sitting, clamped, just waiting for the glue to dry.
fulltimin
Posted: 01/11/22 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I didn't end up where I wanted to today, but I did get some sanding done on the door frames. After spending some time sanding, I then rounded off the edges, both inside and outside on the top, or front edges, if you will.
I had hoped to get the panels cut and glued in today, but it just did not happen.
fulltimin
Posted: 01/12/22 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
I got my router out and proceeded to cut a groove on the backside of the frames I made, so I could put a panel in the center.
Then I cut some 1/8" thick plywood and glued them in place. Just waiting for the glue to dry.
fulltimin
Posted: 01/14/22 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
Sooooooo, I went to Lowes today, and bought a 3 sets of hinges for the doors I just made.
fulltimin
Posted: 01/14/22 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, 3 of these doors.
fulltimin
Posted: 01/14/22 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
After a little drilling, and screwing, we end up with this! Wahoo!
Page of 798
