RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 831
LouLawrence
Traveling the US!
Posted: 08/03/22 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Bruce.
JoeH
Apollo Beach,FL
Posted: 08/04/22 05:39am Link  |  Quote  |  Print  |  Notify Moderator
LouLawrence wrote:
Thanks Bruce.
same here
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
fulltimin
Home is where we Park It.
Posted: 08/04/22 11:19pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Bruce.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 08/05/22 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Back to the sink. Oh no, not the sink. Yes, the sink.
I originally drilled the hole for the drain, and at the time, hadn't thought to include the recess to put the stainless steel drain in.
So, I managed to cut the recess like this, and included a partial pic of my shoe... - you know, for those inquiring minds. (red circle).
fulltimin
Posted: 08/05/22 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Here's what it looks like with the drain just sitting in place.
fulltimin
Posted: 08/05/22 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
I used a contraption like this. After all, if I am going to re-invent the wheel at every turn, well, lets get to it!
fulltimin
Posted: 08/05/22 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a modified version of the hole saw I used.
fulltimin
Posted: 08/05/22 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
I originally used a 2 1/8" hole saw to drill the hole. As such, I cut a piece of mild steel roughly 3 inches long that would fit into the slits in my hole saw.
Then, I cut a taper on both sides, and both ends to allow for some clearance while cutting.
I then drilled a hole in the center of the steel and ran a screw in from the side of the hole saw to hold it in place while using it.
fulltimin
Posted: 08/05/22 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
Here is another view of the hole saw with the adapter I made. I also removed the drill bit that is normally used as a starting hole for the hole saw.
Since I was going to use the outside of the hole saw as my "pilot", there was no need for the drill bit.
fulltimin
Posted: 08/05/22 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Now you can see how this picture makes a little more sense. The drill was attached from the bottom and pulled down to cut the recess. I still need to put finish in the recess to make it water proof before use.
Page of 831
