RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 835
LouLawrence
Traveling the US!
Posted: 08/27/22 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Most likely POR 15.
Bruce Brown
Northern NY
Posted: 08/27/22 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
LouLawrence wrote:
Most likely POR 15.
[emoticon] [emoticon] [emoticon]
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
fulltimin
Home is where we Park It.
Posted: 08/27/22 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
dodge guy wrote:
Are you going to put something over the screws as protection even thought they are countersunk?
Yes. I needed to get this area level, (countersunk screws), so I could cover it. With the hex heads sticking up, that would be a problem trying to put something there.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
Bruce Brown
Northern NY
Posted: 08/28/22 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Seeing as they'll be under the roof material you could just put a strip of gorilla tape over them.
When I did the roof on my TT rebuild I used gorilla tape in the sheeting seams and edges, based on a recommendation from the local RV guys. Worked well.
fulltimin
Posted: 08/28/22 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks.
fulltimin
Posted: 08/28/22 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
If you're still not happy with the stability of your ladder, a little extra bracing could be in order......
Yeah, it doesn't move...
fulltimin
Posted: 08/28/22 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
I finally got all the old gunk off of there, and gave things just a very quick light sanding with 36 grit to remove the final remnants of what is probably, nearly 40 year old, hard as a rock, Dicor.
Even the other side is finally cleaned and lightly sanded. Next I can add some fiberglass near the sides to close up the areas that I had to cut to make the old fiberglass bend and fit the way it needed to.
fulltimin
Posted: 09/01/22 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
I cut off the excess of the screws on the inside on both sides above the pilot and co-pilot's seats. That will allow insulation to be installed there.
The front cap above the seating area had virtually no insulation from the factory, and as such, transmitted a lot of heat into this area.
fulltimin
Posted: 09/01/22 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
I also added a few layers of fiberglass on both sides of the coach above the front seating area.
Adding several more layers, will allow me to build this up and level it out, so it, hopefully, looks like a reasonably nice contour when the Tpo is pulled front and glued down.
I do intend to cover most of this area with the Tpo, as it reduces heat transfer by a very large amount.
fulltimin
Posted: 09/04/22 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
Here's how you know you screwed up and didn't wait long enough for the fiberglass resin to dry, before trying to sand it. Oops...
Page of 835
