RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 835
fulltimin
Home is where we Park It.
Posted: 09/04/22 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
I did, however, manage to get a number of fiberglass layers put into place to try and get things a bit more level before gluing the rubber into place.
Hopefully, one more day of adding glass and resin, and I'll be ready to glue the Tpo in place and be done with this area.
We'll see, as they are calling for rain this week.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
ro_sie
South Carolina
Posted: 09/13/22 04:47am Link  |  Quote  |  Print  |  Notify Moderator
I dont know why I check in here everyday. Sometimes two times in one day.
ro_sie
Art ( my roomie)
Fleetwood Revolution LE
LouLawrence
Traveling the US!
Posted: 09/13/22 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Yes, refreshing isn't it! You don't have to check in if there are no New Post indicator.
fulltimin
Posted: 09/13/22 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry folks, but it has been one **** of a week!
One of my business computer customers banking account was compromised.
As such, I haven't had time to even mow my own grass. Not my favorite sport anyway, but, it needs to be done.
Anywho... I found some other stuff of his online, that needed attention, so I've been spending my time on trying to get all his accounts secured, so this doesn't happen again.
I hope to get back out there within a day or two and get more work done.
I just needed to prioritize.
Thanks for hanging in there. I look forward to getting more done to this puppy.
fulltimin
Posted: 09/15/22 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
Finally! Managed to get out there this evening - albeit a little late.
Also got half the yard mowed today. Yippee. Lol.
I added some extra fiberglass on both sides tonight. I am finally getting this flattened out fairly well.
That means I will be able to finally glue the Tpo down for good shortly.
First pic is of the drivers side. Oh, and yes, I now know my camera lens was a little dirty. Duh on me.
The passenger side also.
fulltimin
Posted: 09/18/22 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
Switching gears just a touch for tonight.
When I wanted to cut some plywood to finish framing around the pilot and copilot windows, I needed to make a pattern.
First step was to mark some plywood to get started. I used a couple of plastic spring clamps to hold this piece in place.
Next was to go outside and and mark with a pencil the curve I needed so I would know where to cut.
fulltimin
Posted: 09/18/22 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Switching to the top of the window, and sometimes, you just need a little helping hand to hold things in place.
A nice extra piece of plywood that is sprung into place from the seat to the top of the plywood covering the window works just fine.
Just as the bottom one, just going outside and marking the curve was a snap.
fulltimin
Posted: 09/18/22 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
In order to end up with a pattern like this for the front of the window at the bottom, required a slightly different approach, since I could not go outside to mark anything.
I wanted to end up with a pattern looking something like this.
Marking a rectangular piece of plywood, at the red circles, gave me a reference point to start the cutting process, but I needed to get a rough reference for the curve at the bottom.
That was accomplished by using what was handy, which in this case was a roll of tape. It's not an exact match to the curve, but it's close enough to get me started, and then I can finish the fine tuning after getting this close.
fulltimin
Posted: 09/18/22 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
Finally was to transfer the curve to the plywood, and then make the cuts on the marks I had just made.
And that is how I ended up with this, which is the same pic as above.
skipsor
Thousand Oaks, CA
Posted: 09/20/22 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
It looks like you are more interested in getting to one million replies that you are finishing you MH.
Page of 835
