RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 590
fulltimin
Home is where we Park It.
Posted: 02/06/19 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
After all that, what did I do today? Well, after leaving the foam board pressed up against the roof for 2 days, I pulled the supports out from that, and proceeded to put up the last 3 foam boards.
Here is a pic of the ceiling as it is now. This finished off the rest of the ceiling/roof, with the exception of the ends, which are the curved portions.
I will leave the braces in place for 2 days before I pull them down, and continue with the curved areas.
That didn't take all that long, since I had already cut the pieces to size before today.
Had a little more rain today, woo hoo! Lol. Ugh...
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 02/07/19 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Here are a couple of things that I have been wanting to do for a while, and just finally got to it today.
First, a while ago I bought a quart of Glidden Gripper, which is a primer/sealer. I painted that on a pair of pieces of wood which were clamped together at a right angle and left to dry.
Here's a pic of it.
fulltimin
Posted: 02/07/19 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
Next I put that "glued" wood into my press, along with my scale to see how much pressure it would take to break the joint.
Here we see the scale sitting at 170 lbs, and just an instant after this was taken, it split apart.
You may remember when testing wood glue with plywood a while back that with those tests, the glue held until well past 400 lbs.
While this did not compare well to wood glue, I was a little surprised that the Glidden held as well as it did, just being a primer.
fulltimin
Posted: 02/07/19 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
Here we see the results after the wood was broken in two. I am not sure how well it shows up in the picture, but some of the wood gave away before the paint, which kind of surprised me.
Granted this was not tested with plywood, but a soft pine, but still, it held pretty well, based on what it actually is for.
fulltimin
Posted: 02/07/19 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
Finally, I wanted to try the Loctite spray foam insulation as a "glue" in between 2 pieces of the green foam board I got at Lowes.
So, I sprayed some on one piece of foam, squeezed them together, and pulled them apart, and took this picture. After taking the pic, I put them back together and weighted them down.
I will let them sit for a day or two, and then try pulling them apart, so I don't have those results yet.
fulltimin
Posted: 02/07/19 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
After doing that, what did I actually DO today?
Nothing!
Had a visitor this morning, and then we had some shopping to do this afternoon. Hey, gotta buy those groceries some time or another.
By the time I got home, it was raining, so I could not cut the excess insulation off of the outside of the coach up front, so I'll get that next day that it's not raining, which is supposed to be tomorrow.
Also, tomorrow, will be the second day for the last 3 pieces of insulation that I put on the ceiling/roof. The supports holding that up are due to come down tomorrow, so I should have more pics of that.
So, with all that vast amount of nothing going on today, tomorrow should be better. Yee Haw!
fulltimin
Posted: 02/08/19 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
After allowing the Loctite spray insulation cure overnight, I pulled it apart today to see what it looked like.
Some of it pulled the insulation apart, but not a whole lot of it. I did manage to transfer the blue lettering from one side to the other, though! Lol. If only that was the goal, this one nailed it.
Pulling these 2 apart took about the same amount of effort as the Great Stuff Foam.
Either way, as a last resort, I guess the spray foam could be used for glue, providing there is sufficient pressure applied to hold them together until it cures. Overall, there are definitely better ways to hold the foam together than using spray foam.
fulltimin
Posted: 02/08/19 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
Next I removed braces today that were holding up the last of the ceiling panels, so the center section is complete. Yee Haw!
fulltimin
Posted: 02/08/19 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
After that, what did I do? This afternoon turned out to be fairly nice, with the sun out, so I decided to remove the extra spray foam insulation from the outside of the coach, that I sprayed in there a couple of days ago.
Here you can see the board and spray insulation are now flush.
fulltimin
Posted: 02/08/19 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know if you have ever had this happen to you, but it happens to me sometimes.
While I am getting ready to work on a certain part of a project, sometimes I don't know exactly how I want to do it.
I can think about it ahead of time, and figure it out before I get there. Other times, even after the thought process, I still don't know until I actually am ready to start that process.
Today was one of those days. I wanted to start putting the insulation on the curved part of the ceiling, but still wasn't settled on how I wanted to do that.
I really did not want to use 2 pieces - one of them 1" thick and the other 1/2" thick to fill in that area. I really wanted to use 1.5", with glue on the top, and be done with it.
Finally I came up with an idea that I thought "might" work. All I needed to do was to try it, with out the adhesive. It worked. Yay.
You may remember that the insulation seems to bend a little better when bending it "across the grain", or from side to side.
That's how I tried it with a twist.
Page of 590
