RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 574
fulltimin
Home is where we Park It.
Posted: 10/10/19 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
Oh, NO! He's at it again.... Thinking. Lol.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 10/10/19 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
Today I took some 1/8" thick plywood that I had left over from the plywood that I put on the inside walls, and cut some of them into strips that are a little over 1.5" wide. Like, so....
Why, you might ask? Because they bend easily, and I need to bend a bunch of them.
fulltimin
Posted: 10/10/19 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
This first step, was to tape a couple of layers to the inside curve of the door frame, like this. That will take up nearly 1/4" of space on the inside of the curve.
fulltimin
Posted: 10/10/19 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
Why would I do that? Because I could. Lol. Next step was to add some more strips on the inside of those and glue them together. That will create an exact replica of the upper door frame.
After adding a few extra layers, I needed to add some clamps. So, that is what I did. Unfortunately, I ran out of clamps.
What is the one thing every woodworker needs? MORE CLAMPS!
Yea, even with all these, I still only had about about 1/2 of what I needed to do the entire door frame. Sounds like another run to Harbor Freight coming up. Lol.
Yea, that's what I did today, and it took a while. Longer than you might think.
Need more clamps, Capt'n.
fulltimin
Posted: 10/11/19 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
Well, today, I started gluing, once again.
This pic doesn't look like much, but I spent some time early this afternoon gluing more strips together, and then tonight, I glued some more. The glue only takes 2-4 hours to cure.
The curved portion is now nearly 3/4" thick, so it won't be long until I can pull this off and continue gluing on the table, which should make things go faster.
Hey, I didn't even have to use all my clamps today. Yay! Lol.
Why am I doing this like this? Well, I figure if I build the outer edges of the door in place, it has to fit when I am done, right? Famous last words, I guess.
Anyhow, This keeps getting stiffer with each layer, so it should not be long until I can skin the one side, then insulate, then skin the other side.
The door frame, (steel portion), is not 100% identical on both sides at the curved portion. It's close, but not quite. That's why I am taking a little extra time to get it, hopefully, fitting correctly.
I can always trim a little off here or there if I need to.
Like I said, it doesn't look like much, but there was a lot of progress today, that the pic just doesn't show.
Wahoo!
fulltimin
Posted: 10/12/19 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
Wahoo! Pulled the partial door frame out today, and continued to add layers of plywood to build up the outer section of the door. I laid it on a small table and just had a great gluing time. Twice, actually. Earlier in the day, and later in the day.
Fun at it's finest?
fulltimin
Posted: 10/12/19 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a section of the outer frame. I've gotten 9 layers glued together, in between the red arrows, and only need to add a few more in this direction.
That means I have about 1" of the outer frame glued together. I think I'll do about 1.5" or so.
Even though this looks like it should only take about 15 minutes, is doesn't. Until I get the plywood cut to length, adhesive applied, then fumble around trying to get everything lined up and clamped, it just takes a while.
Longer than you would think. Then again, that's nothing unusual.
fulltimin
Posted: 10/12/19 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
I want to bring this picture back. The red arrow points to what the outer edge of the door will look like as far as plywood direction.
The yellow arrow points to the orientation of the plywood grain that I will be adding on the inside. Then again, maybe aluminum angle would work well in there. Just thought of that.
Anyway, I want the plywood grain as shown with the red arrow along the edge of the door. Why?
Any screws that I need to add need to be able to grab into something without splitting the wood. Going through the plywood grain as the red arrow shows, will work with screws, nicely. You know, like hinge screws.
If those same screws are screwed into plywood as shown on the left with the yellow arrow, it tends to split the plywood, and has less holding power.
That's the reason for gluing this up that way. This will give me the strength I am looking for, to keep the door straight and sturdy, compared to what was on her to begin with.
Oh, by the way, ignore the mismatched plywood here. This is to explain grain/screw direction only.
Bill.Satellite
Full-timer
Posted: 10/13/19 05:11am Link  |  Quote  |  Print  |  Notify Moderator
If you are using the frame to make an exact copy of the opening and using that as the door, where is the room for the swing the hinged door going to come from? It's one thing to pull the door straight out but another to create a door with the room for hinges and swing.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
fulltimin
Posted: 10/13/19 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Before I started gluing up the door, I added 2, 1/8" strips to the steel frame the door goes into. That will give me nearly 1/4" on each side and top for extra space.
Here is the pic I posted about temporarily adding extra plywood, that will not be part of the door, nor part of the frame. Once the door is built, these pieces will be removed, and I'll have, hopefully, enough of space for the door to swing open and closed.
Should it turn out that, I need more space, I can trim a small amount off of the door itself.
Page of 574
