RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 787
fulltimin
Home is where we Park It.
Posted: 04/27/21 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
Moving to 5 strips and amps are 1.87, with watts at 24.5.
The outgoing voltage drops to 8.40
With 6 strips we are at 1.87 amps, with watts at 24.5.
Outgoing volts are 8.17.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 04/27/21 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Adding another strip to make it 7 in a row, with amperage at 1.88 and watts at 24.6.
Outgoing voltage is now at 8.02.
And the final one with 8 in a row, here we have 1.87 amps, 24.5 watts with an outgoing voltage of 7.93.
fulltimin
Posted: 04/27/21 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
Here is an overview of all 8 hooked together, and you can see that the brightest ones are at the top, with the highest voltage, and they get progressively dimmer as the voltage drops.
fulltimin
Posted: 04/27/21 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
Next step is to take 6 strips, and tie all of the incoming wires together, with the outgoing ends, not connected to anything.
fulltimin
Posted: 04/27/21 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
Now, with all of the incoming leads tied together, our incoming voltage dropped just a touch to 12.99 instead of the 13.11.
All of the strips are getting the same "high" voltage and our amps jump to 3.94 with the watts at 51.1.
Outgoing voltage on any of the 6 strips end up at 10.42.
You can also see that the lights are much brighter, (obviously), as well as using more amps/watts from the supply side, collectively.
fulltimin
Posted: 04/27/21 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
You can't see it in this picture, but I changed the size of the wire between the twisted strip light ends, and the power supply, to a larger size, and this happened.
The supply voltage went down a touch, the amps went up to 4.70, watts at 60.8, and the voltage at the end of any of the strips is now up to 10.80.
Proof that wire size changes things.
fulltimin
Posted: 04/27/21 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
in case you want to look at these lights, here is the link to them on Amazon.
Led link.
Overall, I am happy with them, and they are dimmable, which will adjust the amount of energy used, in case you need to conserve some, or just want some mood lighting.
fulltimin
Posted: 04/28/21 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a pic of the led I have that was used for the preceding comparison. It has 24 led's, 18 of which are spread around the outside, with an additional 6 on the end.
It works well, but I like the string lights more.
fulltimin
Posted: 04/28/21 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
Sometimes the answer you need is right in front of you, if you just look around a little bit.
This skateboard has been a wonderful help to me over the years at times.
fulltimin
Posted: 04/28/21 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Instead of trying to lift a piece of plywood and carry it into the garage all by myself, this makes a wonderful aid.
You know, just like all the off label uses of drugs ---- used for something they were not originally intended for ---- this works well or moving plywood! Wahoo.
I think his falls under the category of working "smarter", not "harder".
This info is worth just what you paid for it. Lol.
Page of 787
