RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 801
fulltimin
Home is where we Park It.
Posted: 04/28/21 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
Moving on. After picking up a piece of 3/4" plywood at the box store.
I moved it into the garage, sliced off a section from the side, and cut that up into pieces that I needed to continue the construction of the frame that I need to support the next set of drawers.
Using the Kreg jig, with glue and screws, I've now gotten the next section of the frame assembled.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 04/28/21 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
Here we have it sitting in place. It's not fastened yet, but that should not take long to fasten it into place.
By the way, all of the drawers under this side of the counter top, will give us roughly about 28 cu ft of storage space.
Not too shabby!
fulltimin
Posted: 04/29/21 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
Took the day off today. Hopefully, tomorrow will be a little bit more productive than today was.
BigRabbitMan
Cottage Grove, OR
Posted: 05/01/21 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
fulltimin wrote:
I wanted to check out a set of strip led's, to light up the counters for cooking and preparing food, etc.
Here's what I found on Amazon.
These have a string of 42 lights end to end, but they are a double set, so they have a total of 84 per strip.
Those look like the ones I have under the cupboards in my house to light up the counters. They work very well.
Here is a larger picture, and every set of 3, (6 lights total), the strip can be cut. Included are a bunch of extra ends that can be soldered to the cut strip if needed.
Both ends come with a connection, so they can be plugged together if you want more than a single string in length.
BigRabbitMan
Gas to Diesel Conversion project
76 FMC #1046, Gas Pusher became a Diesel Pusher
Discussion thread on this site
"You're never too old to learn something stupid."
fulltimin
Posted: 05/01/21 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
As of now, those are the ones that I am planning on using. They provide a lot of light, and look like they should be versatile.
We'll see how they look as the build progresses.
fulltimin
Posted: 05/02/21 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
Got my next set of drawer sides, fronts, and backs cut to size.
I need to cu the grooves, dado's, etc before assembling them.
fulltimin
Posted: 05/03/21 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Another computer emergency today for a customer. Took care of my day for working on the MOHO.
UGH!
fulltimin
Posted: 05/06/21 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
Hey there! Sorry for causing a couple of days of "withdrawal" symptoms for a few of you.
Anyhow, I had a little time to continue working on the next set of drawers.
I cut the grooves for the drawer bottoms, and then started cutting the grooves for the slides in some of the sides. I have 1/2 of those cut, so I can finish the other 2 sets tomorrow.
Forecast is for rain, so I'll not be able to work on other stuff outside, so I should be able to get some work done inside the coach.
Wahoo!
fulltimin
Posted: 05/07/21 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone remember this?
Yes, that's the "ear" that I rebuilt on our Magic Bullet blender, after it had broken off.
If you remember, I first tried gluing the original back on, and that only held up for about a week or two.
Then I created a completely new "ear" from the UV light glue.
It is still holding up just fine. It's been about a month or so. It's still looking good at this point.
I'll wait a little while and see how it goes, that is assuming I remember to post about it. Lol.
fulltimin
Posted: 05/08/21 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
Finally got all my drawer parts cut and machined and are ready to be assembled.
All my grooves and dado's are cut, just waiting for glue, clamps, and plywood. Wahoo!
Page of 801
