RV.Net Open Roads Forum: Tech Issues: Another Megawatt Upgrade Want To Post Article
 > Another Megawatt Upgrade Want To Post Article
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 06/21/17 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
Pictures and text.
Is there an easy to use upload service that can retain a created article? The upgrade article would include the entire process divided into chapters.
Easy disassembly & reassembly
How to choose, buy and install a voltage adjustment potentiometer
If needed, how to replace the weakest components (caps and rectifiers) in the Megawatt. This turns the Megawatt into one tough charger.
These things are not nerd techhie grade mods. If you can handle a cheap 15 watt soldering pencil, you can do this stuff so easy it hurts.
But I need a kindergartener's grade upload site to start the process.
Any ideas?
Thank You
Chris Bryant
Arden, North Carolina
Posted: 06/21/17 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Google Docs?
https://www.google.com/docs/about/
-- Chris Bryant
My RV Service Blog
The RV.net Blog
MEXICOWANDERER
Posted: 06/21/17 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
I am going to heavy-duty examine each suggestion. Anyone can access Google Docs with a correct link to URL?
And THANK YOU Mr. Bryant!
Chris Bryant
Posted: 06/21/17 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
I believe so- try this:
https://docs.google.com/document/d/1J2go........1nklbb4E5GawiBxRztyanQo/edit?usp=sharing
Joe Way
Quincy CA
Posted: 06/21/17 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
Chris...you and the cat have the same expression on your faces...[emoticon]
RLS7201
Posted: 06/21/17 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
Make you wonder which one is really the tech? GRIN..
95 Bounder F53
460/528 stroker
theoldwizard1
SE MI
Posted: 06/21/17 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
I have used Google Drive (just the back end storage for Google Docs) for awhile. It works, but it is not the most "user friendly" way of sharing a document.
You can embed images from your Google Docs/Drive, but again, not user friendly.
* This post was edited 06/21/17 08:47pm by theoldwizard1 *
Chris Bryant
Posted: 06/22/17 07:00am Link  |  Quote  |  Print  |  Notify Moderator
Also, FWIW, http://google.com.mx *might* work better for you- not really sure. That pic is one I had on my Google drive- I posted that on my chromebook, which doesn't have any pics stored on it.
Nick (RIP) was the boss- he's gone now, and I've lost weight and don't wear glasses any more [emoticon]
MEXICOWANDERER
Posted: 06/22/17 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Another tweak upgrade. This addresses the whining about the 10-turn potentiometer.
This is a Bournes 3-turn 500 ohm pot available on e-Bay
">YAAAOSwZKBZE1iD]http://www.ebay.com/it........="cool" alt="[emoticon]">YAAAOSwZKBZE1iD
Naio
Snug as a bug in a rug
Posted: 06/22/17 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
FYI, google drive uses an enormous amount of ram, even for plain text, and takes a long long time to load. I would suggest you try and see if its use of resources is compatible with your setup before putting a lot of effort into it.
It's like pdf files, in that it is at least theoretically accessible to people on any platform, but is a huge resource hog.
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
