RV.Net Open Roads Forum: Tech Issues: Can I double up on wire?
 > Can I double up on wire?
Naio
Snug as a bug in a rug
Posted: 07/01/17 10:57pm Link  |  Quote  |  Print  |  Notify Moderator
Doing this on the megawatt made me wonder: I have a bunch of 8/4 wire, nice and flexible, in heavy housing. Could I run 2 pos and 2 neg, and use it for my battery connections? 2x 8ga = what gauge?
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
Artum Snowbird
Campbell River, B.C., Canada
Posted: 07/01/17 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
Sure you can. Can you get all the wires under the lug at both ends though?
Mike and Carole
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers
Naio
Posted: 07/01/17 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you, Artum [emoticon].
Sure, if I have a long bolt [emoticon]. Can I make good connections, though, is another question...
* This post was edited 07/01/17 11:43pm by Naio *
Hiking Hunter
Warrior, Alabama, usually
Posted: 07/01/17 11:40pm Link  |  Quote  |  Print  |  Notify Moderator
Use this chart.
Two #8s in parallel are roughly equivalent to a #5 in resistance.
Amateur Radio WA4GIY
2015 Montana High Country 305RL
2013 RAM 3500 4x4, crew cab, long bed, 6.7 CTD, Aisin trans.
CGVW 20460 Lbs.
Naio
Posted: 07/01/17 11:42pm Link  |  Quote  |  Print  |  Notify Moderator
Oh, thank you, Hiking Hunter!
That is not as good as I thought.
Hiking Hunter
Posted: 07/01/17 11:47pm Link  |  Quote  |  Print  |  Notify Moderator
Well, since you have a lot of it, run two 8/4 cables and parallel all the conductors? Each cable would be roughly equivalent to a #2!! (If you have the space) Not the best design...
Naio
Posted: 07/01/17 11:53pm Link  |  Quote  |  Print  |  Notify Moderator
Lol, I don't think I will do that [emoticon].
I might use it for the outlets, instead -- two for the shore power, and two for the inverter outlet next to it. Most places, I want one of each.
8ga is overkill, but it is more flexible than romex, and has that nice fat housing.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 07/02/17 01:15am Link  |  Quote  |  Print  |  Notify Moderator
Howzure weak-sister battery doing resting voltage-wise?
folivier
Southeast Louisiana
Posted: 07/02/17 06:26am Link  |  Quote  |  Print  |  Notify Moderator
And if the extra wires won't fit on the battery lug then something like this works well:
https://www.amazon.com/gp/product/B00HZU42Z2/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
Wherever I happen to park
Posted: 07/02/17 07:05am Link  |  Quote  |  Print  |  Notify Moderator
Another thing is if one wire is even a little bit longer the current won't be balanced,,, BUT if you have enough wire.. no problem.
IE if you are likely to pull a max of 200 amps, and your wires are rated at 100 amps each, and you ran 3 or 4 of 'em.. NO PROBLEM.
Home is where I park it.
