RV.Net Open Roads Forum: Class A Motorhomes: Jack stands
ricelake922
Peterborough
Posted: 08/06/17 05:19am Link  |  Quote  |  Print  |  Notify Moderator
Hello. I have a 1996 Monaco Dynasty and am looking for advice as to what size of jack stands do I purchase for my RV with a GVWR of 128,000 lbs? I would like to do some maintenance under the RV and even though I have hydrolic jacks I want to ensure my safety. Thank you in advice in advance.
dalenoel
S.E. Michigan
Posted: 08/06/17 05:30am Link  |  Quote  |  Print  |  Notify Moderator
First, are you sure it is 128,000 lbs? A 48 foot new Dynasty with 4 slides is only 51,000 lbs.
That is alot of weight for an RV with at most one slide.
03 Monaco 36PBD DP - 18 Focus Toad
Wife and myself, Lutheran Deacon, Oreo the Malshi
Sprink-Fitter
Anywhere we want to be.
Posted: 08/06/17 05:40am Link  |  Quote  |  Print  |  Notify Moderator
They must have used some heavy steel on your frame to get to 128,000 pounds. Wow
2006 Coachman Adrenaline 228FB
2012 Can Am Commander XT 1000
mike brez
Unknown
Posted: 08/06/17 06:04am Link  |  Quote  |  Print  |  Notify Moderator
I'm sure this is fat finger issue and is 28k
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
BTPO1
Western US
Posted: 08/06/17 08:06am Link  |  Quote  |  Print  |  Notify Moderator
If it is really 128,000 lbs I believe it is too heavy for the interstate system. I believe trucks are limited to 80,000 lbs. If it is 28,000 lbs I believe that 12 ton jack stands would work as all of that weight is not in one spot. JMO
Jack
2003 Rexhall Vision 27'
2005 Corolla on a Demco dolly with electric brakes
States we have been to with this MH
Mile High
CO
Posted: 08/06/17 08:51am Link  |  Quote  |  Print  |  Notify Moderator
I heard Monaco built a good coach!
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
gbopp
The Keystone State
Posted: 08/06/17 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Assuming your rig is 28k and not 128k, I would get a pair of 12 ton Jack Stands. Nothing smaller.
I believe jack stands are rated as a pair, not as individual units.
12 tons will give you a capacity of 24 thousand pounds. That will be plenty for the front or rear end of your Dynasty.
Two pair will give you 48k capacity.
Use your hydraulic jacks to lift the Dynasty and install the Jack Stands.
ricelake922
Peterborough
Posted: 08/06/17 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Thank you GBOPP for your answer. I will get a pair of 12 ton jacks.
Wherever I happen to park
Posted: 08/06/17 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have 2 six ton jacks I use on my 24,000 pounder That is half the weight.
HOWEVER that said. I can crawl under my rig when it's all the way down (Good ground clearance) and it's getting easer to do as I loose tonnage (Personally) as well.. Down about 1" or 20 pounds fron what I was.
But I use the six ton's in the rear and 4 in the front (2 ton each) and never fully unload the springs or lift the wheels off the ground. Have not had an issue doing that.
My RV" hydraulics are ... Non functional at the moment
Home is where I park it.
msmith1199
Reno, NV
Posted: 08/06/17 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Just a typo, like your typo on a 48 foot Dynasty? Don't think they come that long.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
