RV.Net Open Roads Forum: Truck Campers: Low-propane alarm
 > Low-propane alarm
hedgehopper
Denver
Posted: 08/10/17 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
On several occasions we have discovered that our refrigerator is running on 12 volts because we are out of propane. Has anyone figured out a way to sound an alarm when the fridge switches from propane to 12 volts because the propane tank is empty?
Old-Biscuit
Verde Valley
Posted: 08/10/17 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
Don't run out of propane
Two 20# cylinders.....that is a lot of propane.
Pay more attention to usage and fill empty soon after auto swap happens.
Might invest in a DC Voltmeter will LOW Voltage Alarm.
https://www.bluesea.com/products/8251/DC_Digital_Voltmeter_with_Alarm
work2much
Jackson Ca
Posted: 08/10/17 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
Our fridge has setting for LP, DC and AC. Also "Automatic to go from AC to LP and finally DC.. Check to see if your fridge has setting to only use the one source you want or nothing.
2017 Ram 3500 Laramie DRW Crew 4x4 Aisin 4:10 Air ride.
2018 Host Mammoth. 1080 Watts solar. 600 AH usable battery. Magnum 2800 Watt inverter.
K Charles
Connecticut
Posted: 08/11/17 07:05am Link  |  Quote  |  Print  |  Notify Moderator
They make an alarm that you can put on your changeover valve. If you changed the tank then you would not run out.
Chris Bryant
Arden, North Carolina
Posted: 08/11/17 07:50am Link  |  Quote  |  Print  |  Notify Moderator
I cannot think of any model that will switch to DC without intervention, other than tag line controlled models. Most that I know of are automatic AC/LP, but need to be manually switched to DC.
What is the make and model?
-- Chris Bryant
My RV Service Blog
The RV.net Blog
hedgehopper
Denver
Posted: 08/11/17 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
2002 Northern Lite 10-2 CD
Kayteg1
California > Nevada
Posted: 08/11/17 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Fridge can run about a year on 5 gallons of propane, so I wonder how you can run out of propane so often.
Last time I run out of propane was 12 or 15 years ago, so if fridge switches to 12V on such occasion- I would not know.
So as suggested above, don't run out of propane.
time2roll
Posted: 08/11/17 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.rvupgradestore.com/AP-Produc........01-Propane-Level-Indicator-p/06-2191.htm
675w Solar pictures back up
hedgehopper
Denver
Posted: 08/11/17 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
The furnace and the range use propane too.
Moreover, we have had the camper for three years. And for a while we had a propane leak that we were not aware of.
hedgehopper
Denver
Posted: 08/12/17 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
This idea has possibilities. Now if I could figure out a way to make it sound in the cab as well as in the camper, that would be great.
 > Low-propane alarm
