RV.Net Open Roads Forum: Truck Campers: Repair stripped screw holes in fiberglass
 > Repair stripped screw holes in fiberglass
bkenobi
98101
Posted: 08/11/17 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
A couple of the mounting screws for the ingress handle on my NL are stripped. If this were wood, I'd glue a toothpick in there and move on. What is the best approach for stripped fiberglass?
mobilefleet
on the road
Posted: 08/11/17 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
A golf tee is better, with wood glue. Fiberglas is only a super thin layer and is bonded to plywood anyway. Fill hole with glue, Insert the golf tee, cut it off with hacksaw or multi tool flush with the outside.
bb_94401
Columbia Falls. MT
Posted: 08/11/17 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
I'd wax the area around the hole to prevent epoxy outside the hole from bonding and make it easier to remove. Then fill the hole with chopped strand reinforced, epoxy based paste / putty. Cover the hole with blue masking tape to keep it in place. After it sets, remove the tape, wet sand the area to remove unwanted material outside the repaired hole. Drill a hole for the screw, tap it and then reinstall the screw.
Easiest way to get what you need is to go to your local marine store:
Fisheries Supply
1900 N Northlake Way
Seattle, WA 98103
and talk to someone in the resin / fillers / fiberglass section. Explain what you are trying to do and they will point you in the right direction and explain how to do it.
'05 Ram 3500, 4x4, DRW, LB, 6spd man, CTD, PRXB exhaust brake, Roadmaster bar
'01 Corsair 10'8" - 4,200 lbs., Xantrex XADC 80A, Link 20, 4-Lifeline GPL-4CT, PowerGate Isolater, 2 AWG wire, PI 30A EMS, 2 Honda EU2000i, parallel kit, ext. duration tank.
Photomike
Southern Alberta or where the camper is parked!
Posted: 08/11/17 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
As mentioned the fiberglass is really thin and has no strength in itself. You want to get to the wood behind it and secure to that.
Filling the hole as mentioned above with the wood and glue, put he screw in and you are done. No need to fill the fiberglass hole unless you have a crack that is running as all you are going to do is put another hole in it.
2011 Majestic 19G
2017 Ford Transit (conversion underway)
EVO Electric bike
Advanced Elements Kayaks
Border Collie Guard Dog
bkenobi
98101
Posted: 08/11/17 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
I was pretty sure there was only plywood in the basement area of NL TC's. The outer fiberglass may be thin, but what's behind it? I thought it was a rigid foam of some kind. I missed talking to the dealer this evening but if they confirm wood backing, I'll just glue wood in there. If it's fiberglass, I guess the marine store is a good choice. Heck, I've talked to the NL tech guy a few times, so he's another option (next week).
JoeChiOhki
Sauvie Island, OR
Posted: 08/11/17 11:19pm Link  |  Quote  |  Print  |  Notify Moderator
Fisheries Supply
Seattle, WA 98103
Wish they were closer, I'd love some of their help for my up coming fiberglass work.
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
bb_94401
Columbia Falls. MT
Posted: 08/12/17 01:42am Link  |  Quote  |  Print  |  Notify Moderator
Fiberglass construction usually makes use of backing plates when they want to attach something with screws or bolts that will have a lot of pull out force on it. Foam core construction uses epoxy plugs between the two fiberglass layers for attaching things where the force is more in shear.
If there is no access behind where the screws goes just through fiberglass and there is no backing material, then the most common approach is to use the screws to hold and locate the part until a high strength polyurethane adhesive cures (SikaFlex or 3M). Tensile strengths are in the range of 170 to 500 psi. It is what attaches the access ladder to the roof on my TC, the screws aren't really doing anything.
jesseannie
BOISE IDAHO
Posted: 08/12/17 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Are you going to reattach the handle in the same place? It seems like making a structural repair or an aesthetic one would be different.
Jesseannie
bkenobi
98101
Posted: 08/12/17 08:51am Link  |  Quote  |  Print  |  Notify Moderator
I temporarily used a could toothpicks and reinstalled in the same spot. I want to put it in the same location with a permanent fix.
jesseannie
BOISE IDAHO
Posted: 08/12/17 09:18am Link  |  Quote  |  Print  |  Notify Moderator
I think finding out what is behind the glas is the first step. Then perhaps a nice looking stainless steel sheet bigger than needed glued and screwed to the glas then screw the handle through that into a fresh spot an inch or so away from the original. Reinforced with the stainless and in a new location I think you would golden.
Jesseannie
