RV.Net Open Roads Forum: Truck Campers: Repair stripped screw holes in fiberglass
 > Repair stripped screw holes in fiberglass
tattoobob
Billerica, Ma.
Posted: 08/12/17 10:27am Link  |  Quote  |  Print  |  Notify Moderator
I would try a screw one size bigger first, 99% of the time that has worked for me
2005 Ford F350 SRW 4x4
2000 Lance 1010
theoldwizard1
SE MI
Posted: 08/12/17 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Use a cheap plastic hollow wall anchor.
umpqua
Oregon
Posted: 08/12/17 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Battling the same problem with my Bigfoot.
I used epoxy to set 2-3 tooth picks into each hole. The holes are in a stud, so I have something to grab into. I did upgrade to longer 1/4 x 2" SS lag bolts. The epoxy I used was 12 hr cure, so I'll finish tomorrow.
Tomorrow I will drill a pilot and reinstall the handle. There is another website/forum where this issue was addressed. I used suggestions from that site with some advisory from here.
2006 Ford F350
2004 Bigfoot 2500 10.6
bkenobi
98101
Posted: 08/12/17 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
Link?
Ste7of1
Midwest
Posted: 08/13/17 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
If you are only dealing with fiberglass (no wood backer to grab) another option would be to install a small rivetnut through the hole. This would grab on both sides then you can use a machine screw into the rivet Nut (sized to match) to secure. This approach does require a rivet tool for the rivet Nut installation. For example: https://www.amazon.com/eBoot-Plated-Carbon-Insert-Nutsert/dp/B01NAHXLJM/ref=sr_1_2?ie=UTF8&qid=1502663312&sr=8-2-spons&keywords=Rivet+Nut&psc=1
If you have access to the backside of the panel you can use a weld Nut instead of the rivet Nut eliminating the need for the rivet tool. https://www.mcmaster.com/#90860A100
* This post was edited 08/14/17 08:47am by Ste7of1 *
username taken
Posted: 08/14/17 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
This stuff is great for fiberglass. It's an epoxy putty you knead together and jam in the hole - makes for a much better screw mount than the original fiberglass. In all truth, the bigger and more ragged the hole, the better this stuff works.
https://www.westmarine.com/buy/west-marine--marine-rx-epoxy-repair-kit-2-oz--13967443?recordNum=11
NL uses UHMW polyurethane behind the fiberglass for any kind of load bearing screw. You can get 2x2x 1/2 blocks of it at a good industrial hardware store. Screws will not strip that kind of thing out.
covered wagon
Posted: 08/14/17 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
I'm the guy that first told Northern Lite about how to do that to hold their lower awning hardware and fix stripped screws and leaks. I removed the tailites and was able to get it up in there with my arm. Other areas of striped screws I removed the door frame to batteries or compartment, water fill door, whatever, exposing the fiberglass cut out edge and shoving a half inch thick piece between the shell and bead board with a knife edge or bevel cut on the uhmw so it allows you to force it into the bead board and hold it in there. I had many leaks with a new camper and fixed them all by holding firm like supposed to be.
errante
travelin
Posted: 08/15/17 09:31am Link  |  Quote  |  Print  |  Notify Moderator
As mentioned, if you can get to the backside that would be best, but that is usually not possible. There are many ways to deal with this depending on the situation but I have always had the best luck with the following. Remove the fastener and roughen the hole. This may involve taking a drill bit and going through the fastener hole and drilling off in 2-3 directions a short distance, always being aware of where you are headed. Thoroughly dry the hole. Tape off around the hole. I use an epoxy with a high strength filler. I personally prefer west system but there are many other brands available. West system has a small repair kit for such things(or at least they use to). You will need to purchase either denatured alcohol or acetone for clean up. Fill a small plastic syringe with mix of epoxy and filler. These plastic syringes can be purchased at west marine or similar store. Check it out online. Lubricate the appropriate fastener with wd-40 or similar. Squeeze the epoxy mix into the hole and screw the fastener, without the handle, about the right distance into the hole. Remove tape and clean up immediately. Let cure for 24 hours. Remove the fastener add a little bit of chalk, just because, and reattach handle.
SidecarFlip
SE Michigan
Posted: 08/15/17 11:09am Link  |  Quote  |  Print  |  Notify Moderator
I'll remember the glued in golf tee trick.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
