RV.Net Open Roads Forum: Truck Campers: water heater connections
 > water heater connections
bluearc
Pa
Posted: 08/12/17 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Can someone describe this type of connection and how it comes apart.
thanks
Old-Biscuit
Verde Valley
Posted: 08/12/17 11:04am Link  |  Quote  |  Print  |  Notify Moderator
thanks
[emoticon]
Description
What is it attached to?
Kayteg1
California > Nevada
Posted: 08/12/17 11:18am Link  |  Quote  |  Print  |  Notify Moderator
WH has plumbing holes with 1/2" pipe thread.
Going from there different TC builders use different materials.
Copper usually have flare fitting. Plastic pipes, compress washers.
If you are not familiar how to deal with it, better call professional.
Small crack on the tubing in hard to access space can turn pretty costly mistake.
SidecarFlip
SE Michigan
Posted: 08/12/17 11:46am Link  |  Quote  |  Print  |  Notify Moderator
They all use some type of compression fitting for the transition, but PEX requires a crimp collar and a specialized tool to apply it
Pictures would be helpful. That way Mr. Biscuit won't wear a hole in his head....lol
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Old-Biscuit
Verde Valley
Posted: 08/12/17 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
PEX crimp removal
https://www.youtube.com/watch?v=SLH25bcXxZw
bluearc
Pa
Posted: 08/14/17 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Im having trouble posting pictures of the tank. The fitting is located behind the hot water tank, it is a 90deg into the tank.
I tried this below, but got discouraged about half way through.
Profile and Signature Pictures (RVSnowbird)
Posting pictures within text messages (RVSnowbird)
Signatures
How to place a picture in your signature (pulsar)
Size requirements - where and how to upload picture.
I get an error message when I attempt to upload a picture to my signature (pulsar)
General cause of the error and what to do about it.
Post your signature picture here (RVSnowbird)
Show off your signature picture here.
Resized, Panorama and multiple picture signatures (RVSnowbird)
Using irFanView to resize and/or combine pictures
Make your own signature license plate (RVSnowbird)
Using Win-XP to resize photos for your "Signature" (RVForever)
What program are most using to resize for signature (joeneal)
Add a Visited States Map to your signature (egrove)
How to make a US, Canadian or Mexican map and upload it to your signature.
Combining signature maps using MS Paint (RVSnowbird)
Can't see pictures because of preferences - tutorial (pulsar)
Where and how to change this preference setting
Posting pictures in text
Screen resolution for pictures in text (RVSnowbird)
Posting Pictures Using TinyPic.Com For The Host Site (pulsar)
Tutorial with pictures - Uploading to TinyPic.Com, Selecting the correct URL, using the Image tool, resizing, if necessary. No account required.
Posting Pictures Using PhotoBucket.Com For The Host Site (pulsar)
Tutorial with pictures - Uploading to PhotoBucket.Com, Selecting the correct URL, using the Image tool, resizing, if necessary. Assumes that pictures are already in Photobucket.Com web album
Posting Pictures Using Picasa For The Host Site (pulsar)
Tutorial with pictures - Assumes that pictures are already in a Picasa web album
Posting Pictures Using Imgur For The Host Site (1492)
Video tutorial. No account required.
Click to enlarge pictures within text (RVSnowbird)
Advanced technique. Shows how to insert a normal size picture that will enlarge, when clicked on.
Embedding a link within a picture (RVSnowbird)
Picture Hosting? (before posting a picture within text, it must first be on a host website)
Picture Host Information (RVSnowbird)
Alternate Quick Picture Hosts (RVSnowbird)
Other:
Alternate "portals" to the RV.net Open Roads Forums (RVSnowbird)
There are several ways to enter the Open Roads Forum. If you are having trouble with one, you may have more luck with another one.
How is membership "status" determined? (pulsar)
Why am I still a new member? Or how do I become a senior member?
Displaying the Good Sam logo (pulsar)
How to display or turnoff the display of the Good Sam Club logo seen at the left side of many forum members's posts.
10 tips to posting in the RV.Net/Forums (RVSnowbird)
10 reasons for a red X instead of a picture (RVSnowbird)
Using the message toolbar and 4UMS code (RVSnowbird)
d3500ram
Colorado
Posted: 08/14/17 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Just go to THIS SITE and drag n' drop the file (or browse to it) and then copy and paste the resulting string into your reply text wordage.
AnEv942
CA
Posted: 08/14/17 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Similar to ours.
Ours and most use a swivel connection that threads onto water tank. Ive seen pictures of fittings without swivel that were threaded onto tank and then lines crimped on-
hopefully yours isn't one of those- a bit more involved.
Our camper projects page
bluearc
Pa
Posted: 08/21/17 07:27am Link  |  Quote  |  Print  |  Notify Moderator
I went to a few places like HD and Lws but could not find a matched a fitting, I need the swivel 90 going in the tank.
AnEv942
CA
Posted: 08/21/17 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Suprising-though never looked
online shows it at HD/lowes if you have the sharkbite tools, ring also needed. Assuming line end
http://www.homedepot.com/p/1-2-in-Brass-........wivel-90-Degree-Elbow-UC532LFA/202270585
https://www.lowes.com/pd/SharkBite-1-2-i........X-Adapter-Elbow-Crimp-Fitting/1000182985
https://www.amazon.com/SharkBite-UC532LFA-Swivel-Elbow-2-Inch/dp/B007AHJA1Q
push to connect brass
http://www.pexuniverse.com/1-2-x-1-2-fnpt-swivel-elbow-push-fitting
Flair-it also makes compression ells
https://www.amazon.com/gp/product/B000BQSUX2/ref=s9_acsd_hps_bw_c_x_2_w
