Dennis M M
Winter in Tucson, AZ; summer on the road
All good advice. Here is a link to the Cat Scale website explaining how to weigh. There is also a link there to find a scale near you.
https://catscale.com/how-to-weigh/
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'13 smart CityFlame on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
loggenrock
New Hampshire
Cat or recycle/moving/gravel scales are fine, but won't give you a side-to-side balance weight. Organizations such as the RV Safety and Education Foundation www.rvsafety.com will do 4-corner weights - cost $60 when I did it - and will give you the recommended tire inflation pressures for whatever tire you are running based on the weight they are carrying. ST
Two and a hound in a 2015 Coachmen Prism "B+"...pushed by '09 Suby Forester
First 50 done, working on the second pass! Nunavut - we'll see...!
2005-2015 Roadtrek 190P
1993-2005 Northstar Soft-Side TC
1989-1993 Backpacks & Tents!
1967-1977 Family TT's
j-d
Sunny Florida USA
loggenrock wrote: Cat or recycle/moving/gravel scales are fine, but won't give you a side-to-side balance weight.
Correct, and CAT even mentions in "How to Weigh Motorhome" that they cannot provide side to side (or maybe they say corner) weights.
But PLEASE - Let's get off the dime here and go to a nearby CAT scale. Pony up $10 and get enough information for a good start.
If God's Your Co-Pilot Move Over, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100 218" WB
cvk
Here’s how I weighed all four corners at empty truck scales. Weigh front axel, then rear axel, back up and weigh passenger front tire then passenger rear. Simply subtract the one front weight from the total front and do the same with rear. Easy peazy alll done.
F1bNorm
Gardena, CA
Here's what the Michelin Truck Tire chart looks like. https://www.rvsafety.com/images/pdf/michelinloadandinflationrvtruck.pdfhttps://www.rvsafety.com/images/pdf/michelinloadandinflationrvtruck.pdf
Weigh your MH and find the chart for your brand, model and size tires. At max pressure, my 24' B+ wanders all over the highway, much better handling at the corrected pressure.
F1BNorm
Harvard
51.6N 114.7W
F1bNorm wrote: ... my 24' B+ wanders all over the highway...
POPULAR MECHANICS MAY 1973:
START QUOTE:
If too little caster exists, the car will wander and weave,
thus necessitating constant corrections in steering.
END QUOTE:
OP, dont' get bogged down with 4 corner weights and being accurate to the pound.
Moreso, don't worry about it at all until you have it loaded to camp again.
Get a quick weight of each axle at a closed DOT scale or a transfer station or somewhere, free. Farm country?, grain elevators typically have scales.
Then you know.
You could be fine with 30 psi (not likely) or need 80 psi.
If it drives reasonably well like it is and the tires aren't bulging, it's not grossly over or under as it sits.
Cheers!
2017 Heartland Torque T29
time2roll
j-d wrote: Whatever the Chassis manufacturer (Ford? Chevy?) sticker in the door jamb says, is THE MAX. That is almost certainly less than the 80 PSI on the sidewall of a Load Range E tire. I respectfully disagree. The tire sidewall is the max always. The door sticker is the manufacturer's recommendation for ride, safety, handling and comfort with the expectation the user stays within the weight ratings.
I prefer mine a bit firm so I would be running 5 to 10 psi over the door sticker not to exceed the tire sidewall max.
675w Solar pictures back up
JaxDad
Greater Toronto Area
The whole subject of tire pressure is one I find amusing, the part about ‘4 corner weighing’ hilarious!
Tire pressures are of course best taken when the tires are cold. However, as a tire starts to roll that little flat spot at the bottom, and the 2 little bulges in each sidewall, move along the circumference of the tire to stay in contact with the road. This flexing and relaxing cause heat. An average size tire turns about 750 times to cover a mile, so at 60mph those tires turn 750 rpm. After just a half an hour the tire temperature can rise 50 deg’s. Tire pressure increases by about 1 degree per 10 deg increase in tire temperature.
From the time you check tire pressure at say 9am and find then at say 60 deg’s, to a sunny hot afternoon of 90 deg’s and 6 hours of highway driving the tire pressure could have easily changed by 10 psi.
Oh, but on a snowbird dash south on a cold rainy early winter day, they may have only increased by 3 or 4 degrees.
So much for precise pressure settings ………
4x4van
California
time2roll wrote: j-d wrote: Whatever the Chassis manufacturer (Ford? Chevy?) sticker in the door jamb says, is THE MAX. That is almost certainly less than the 80 PSI on the sidewall of a Load Range E tire. I respectfully disagree. The tire sidewall is the max always. The door sticker is the manufacturer's recommendation for ride, safety, handling and comfort with the expectation the user stays within the weight ratings.
Tire manufacturers have no idea what vehicle their tires are going to be installed on; none. The number on the tire is for the TIRE's max load, and will most times be significantly higher than a particular RV will ever require. That's why load charts exist.
The RV manufacturer on the other hand knows exactly what the maximum GVWR on their vehicle is, and lists (on the doorjamb) the pressure required for that weight. Since the rig should never be loaded above that, any increase in pressure is not necessary, and will not improve ride, safety, handling, etc. Depending on the actual weight of the rig, the door tag numbers may be higher than necessary, but never lower.
edited 12/29/21 10:16am by 4x4van *
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
