RV.Net Open Roads Forum: Truck Campers: Cabinet hardware recommendations
 > Cabinet hardware recommendations
Freep
Wisconsin
Posted: 08/31/17 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Kayteg1 wrote:
The pictured doors have solid wood, at least on the frames and at 17 years they hold perfectly, so let's hear what model of Lance you have with so many problems?
For stripped screw holes, I would just get some epoxy and dip toothpicks in it to insert into the holes.
Give it overnight to dry and it is going to be stronger than original.
It's a 2014 992.
I'm not sure why it's not showing up in my posts anymore.
2014 Lance 992
2014 Ram 3500 DRW Turbo diesel
Kayteg1
California > Nevada
Posted: 08/31/17 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
It is showing, but too often members don't change signature when they change RV and in case like that you don't want false accusation.
Commenting on the issue "they don't build them like that anymore"
Freep
Wisconsin
Posted: 09/01/17 08:03am Link  |  Quote  |  Print  |  Notify Moderator
OK thanks. So epoxy and toothpicks, not wood glue?
I actually told my wife I could use toothpicks and glue during the trip and she was skeptical. I probably would have done it if I had something better than crazy glue or jbweld available.
mkirsch
Rochester, NY
Posted: 09/01/17 08:11am Link  |  Quote  |  Print  |  Notify Moderator
That is a common carpentry repair for stripped screw holes in wood. Don't you watch TV at all? This Old House, half the shows on HGTV and DIY network... all at one time or another show this repair. It's a good low budget way to fill 5 minutes of airtime.
Epoxy, wood glue, even crazy glue will work in a pinch. Epoxy has the advantage of being cheap, and having a version that cures completely in 5 minutes so you are not sitting around all day waiting for the glue to dry. Crazy glue is expensive if you buy the stupid little metal tubes.
If you want to be more sophisticated use hardwood dowels instead of toothpicks. Drill out the hole for the dowel, epoxy the dowel in, trim off flush with the surface, and drill a new hole in the dowel.
Freep
Wisconsin
Posted: 09/01/17 08:24am Link  |  Quote  |  Print  |  Notify Moderator
That's where I got the idea to use toothpicks and I knew we had them, superglue and a drill available. But I had to convince my wife first, since it's her TC.
I think the screws are too small for this application. I'm pretty sure I'm going to just replace them all while I'm at it.
I also like the dowel suggestion and I think I'm going to go that route and maybe add a little more wood on the back side too since the wood is already thin and cracked.
Thanks for chiming in.
Kayteg1
California > Nevada
Posted: 09/01/17 09:19am Link  |  Quote  |  Print  |  Notify Moderator
For stripped holes you need a glue that is also a filler, what Crazy Glue is not.
Water-based wood glue will take days to dry, so IMHO hard to beat epoxy.
If that is emergency, use 5 minutes epoxy, but those are expensive.
I am buying epoxy in 1 gallon container for laminating. That one gives you time to work before it sets, that is why I say give it overnight.
AnEv942
CA
Posted: 09/01/17 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Sigs only show once (per page)
Round toothpicks or wood match sticks and wood glue.
Usually unless a thru hole or really wallowed I dont let it set before threading screw (cabinet screws). Cant imagine your hinges wore out. We replaced ours, they were sloppy and barrel leaves splitting (other than bright shiny brass). Use the same size small screws, and several got toothpick 'backing'
Our camper projects page
Freep
Wisconsin
Posted: 09/04/17 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
OK, I feel kind of stupid. I asked my father in law to take a look at the cabinets and he asked me if the wood was stripped on the cabinet or the door. It's the cabinet.
"Just drill through the cabinet and use bolts with lock washers."
Simple and effective.
stevenal
Newport, OR, USA
Posted: 09/08/21 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
After a water bar unloaded my kitchen cabinets onto the floor and dogs, I supplemented the hinge struts with magnet style latches from Amazon. I think they were rated 60 lbs each, and ended up with two per cabinet. Must be a problem with the conversions, because there is no way it takes 120 lbs to open. It does take a sharp pull however. Also ditch the included screws and get some good ones.
'18 Bigfoot 1500
Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
c.traveler2
Moreno Valley,Ca.
Posted: 09/11/21 07:44am Link  |  Quote  |  Print  |  Notify Moderator
Freep wrote:
During the last trip we had to tape a cabinet shut because the hinge had come loose. We've been frustrated with the latches and hinges in the Lance camper for some time now and I think I need to just go ahead and replace it all. I'm sure some of you guys have already gone through this process and I'd like some suggestions please.
One other item I'd like to replace is the latch for the wet bath. It's this weird little button latch that doesn't work well. In fact, I ended up locking myself in the bathroom during the last trip when I shut the door and then couldn't open it from the inside. That stupid thing has to go.
BunduvryUSA uses this type of cabinet latches, they won't come open once set. Never had any cabinet doors come open with these lacthes regardless of how rough the road was.
push button latch
2007 F-250 4x4 /6.0 PSD/ext cab/ 2020 Bunduvry
Lance 815/ 85 watts solar panel (sold)
2020 Bunduvry by BundutecUSA
Travelingman2 Photo Website
Truck Camper Trip Reports 3.0
travelingman21000 YouTube Videos
Alex and Julie's Travels Blog
