RV.Net Open Roads Forum: Tech Issues: Window air conditioner with a twist
 > Window air conditioner with a twist
SaltiDawg
MD suburbs of DC
Posted: 09/11/17 11:36am Link  |  Quote  |  Print  |  Notify Moderator
!@#$% I am now trying imgur, haven given up on Photo Bucket.
Still can not figure out what link to use.
* This post was edited 09/11/17 03:06pm by SaltiDawg *
Bill.Satellite
Full-timer
Posted: 09/11/17 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Read this post. https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27694224.cfm
Easy as pie!
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
SaltiDawg
MD suburbs of DC
Posted: 09/11/17 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, Bill.Satellite
Acampingwewillgo
Posted: 09/11/17 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, that's pretty much what I had in mind!!! :-)
96 Vogue Prima Vista
The Kid's: Mollie, King Charles Spaniels, Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund mix
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie and Cassie- RIP kids! Love You!
Rally's and get togethers-Lots
SaltiDawg
MD suburbs of DC
Posted: 09/11/17 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
What, a broken tail light?
Acampingwewillgo
Posted: 09/11/17 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like he is at least Wally Docking....lots like a Walmart parking lot. :-)
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 09/12/17 04:28am Link  |  Quote  |  Print  |  Notify Moderator
In my rig I find one unit is great for 12' length with a 20 degree Delta T but the space has to have closed doors and the rig has to be shaded. With a bunch of windows a 5K unit is going to be hard pressed. If the rig has 240 available an 8 or even 12K would be a sure thing.
Acampingwewillgo
Posted: 09/12/17 11:53am Link  |  Quote  |  Print  |  Notify Moderator
Yep...I'm thinking 8-10,000 BTU mainly for the extra room I may get to work on that intake and exhaust issue....the more I think about it, the more I want to get out and do some trial and error....I'll get to it after a few other projects are finished.
Acampingwewillgo
Posted: 09/15/17 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
I should probably start a different Topic for this but here goes....I'm guessing I'm not the only person with a Pusher with a dash air that does not work...I always get a chuckle out of used MH Ads when they emphasize that the dash air works!
Anyways, as I was sitting in the MH today while my brother was over, he says, why not just get the MH air fixed and as usual, I explain that if it were only the rear compressor, I'd do that in a heartbeat but more than likely, it's a leak in one the the lines going to the front condenser.
As I thought this to myself, I wondered if anyone had EVER( in my case, my 10KW generator is up front) put the air conditioning compressor on the generator engine? Now of course I realize that you'd have to have the gen running in order to do this, but it sure would lessen the length of tubing required to replace that run from front to rear not to mention the higher efficiency it would afford. I Know, kinda far out there but what the heck.
MrWizard
Traveling
Posted: 09/16/17 12:18am Link  |  Quote  |  Print  |  Notify Moderator
i really doubt that there is shaft extenstion
you would have open up the generator housing cut slots, change or add a pulley belt and clutch
why do you think there is a fault/leak in the tubing ?
unless you KNOW you damaged it somehow, that would be last thing suspect
buy some leak detector spray, charge the system with freon
craw under there and spray everything
then you WILL know what is going on
Radiate The Happy
1997 F53 Bounder 36s
