RV.Net Open Roads Forum: Fridge cools on A/C but not on Propane - EDIT: FIXED!
 > Fridge cools on A/C but not on Propane - EDIT: FIXED!
cpachristopher
Central Oregon
Posted: 09/07/17 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
He is not coming back for sure. I hadnt considered pressure. Ive got a spare regulator I'll have to try. Stove and water heater are acceptable for what it is worth,
So a good cleaning of the burner/flue/etc and check regulator. Sounds like a fun Saturday
dougrainer wrote:
If it works on 120 and not good on LP and the flame ".looks" OK. THE FIRST THING ANY COMPETANT TECH DOES IS VERIFY THE LP GAS PRESSURE. NOT doing that shows lack of knowledge and skill and I would not hire/use this part changer anymore. A 1 inch drop in LP pressure will have a drastic affect on the cooling capability and you will not be able to tell by the flame size/look. Doug
2015 4Runner towing a cute little Coachmen 16FB
midnightsadie
ohio
Posted: 09/07/17 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
the taking apart and cleaning should be less than an hour U tube how to clean a rv refrig. its not hard. they were made to be removed and cleaned. DO NOT MAKE THE ORFICE HOLE ANY BIGGER.
SidecarFlip
SE Michigan
Posted: 09/07/17 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Lets elaborate on that a bit.... soak the orfice in isopropyl (think thats ciorrec) alcohol and don't even think about sticking anything in the hole. Blow it out with air only. Some have a small piece of sponge inside that acts as a filter that will need cleaning too.
Have fun, be careful with the parts and take your time.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
billyray50
North Dallas
Posted: 09/08/17 11:44am Link  |  Quote  |  Print  |  Notify Moderator
dougrainer wrote:
If it works on 120 and not good on LP and the flame "looks" OK. THE FIRST THING ANY COMPETANT TECH DOES IS VERIFY THE LP GAS PRESSURE. NOT doing that shows lack of knowledge and skill and I would not hire/use this part changer anymore. A 1 inch drop in LP pressure will have a drastic affect on the cooling capability and you will not be able to tell by the flame size/look. Doug
That's what was going with mine. 4 year old regulator was bad. Installed new regulator and works fine now.
cpachristopher
Central Oregon
Posted: 09/10/17 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
Yesterday I cleaned the burner (gently as noted above) and ran a bore snake through the flue. This morning, the fridge was warmer than last night, and the heat coming off of the cooling fins was not nearly as great as the heat when running on A/C.
At this point, I think I'll buy a new regulator, since every web-site I've looked at since you folks pointed it out suggested I carry a spare in any case. If it doesn't fix the problem...no clue, but if it does, I'll be thrilled.
Looking for a regulator, do I just buy an exact match of what I've got or is there a suggestion for a "better" one? I don't plan to run two tanks.
pnichols
Santa Cruz Mountains
Posted: 09/11/17 12:24am Link  |  Quote  |  Print  |  Notify Moderator
Hmmm ... after reading this thread, I'm scratching my head as to what a new gas regulator might have to do with the OP's problem? If the flame is the proper size and makes a loud enough burning sound ... then how can a new regulator do anything?
I suspect something else is wrong with the refrigerator that is causing electric heat to have an effect that flame heat doesn't have. Isn't a BTU a BTU?
Phil, 2005 E450 Itasca 324V Spirit
cpachristopher
Central Oregon
Posted: 09/12/17 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to those who helped. I installed a new regulator ($40 and 5 mins of my time) and let it run all night on propane. The fridge is full of nice, cold bottles of water.
I am more than a little pissed that the "professional" RV repair guy I hired didn't even mention it or test the propane. I sure didn't know about it, but I'm just some office dweller!
Thanks again. Going camping this weekend with a cold fridge will be nice.
Boon Docker
Posted: 09/12/17 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
You better replace those cold bottles of water with cans of beer before you go. [emoticon]
time2roll
Posted: 09/12/17 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
You replaced the regulator at the main supply?
I don't think the fridge has a regulator.
I would have recommended Cavagna brand but with a single bottle they are probably all about the same. How old was it? IMO about 5 to 10 years and they are high suspects to trouble.
675w Solar pictures back up
cpachristopher
Central Oregon
Posted: 09/12/17 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced the main supply regulator.
Funny, when I lit the stove to get the propane going, it put out a much better flame than before!
