RV.Net Open Roads Forum: Tech Issues: Converting 30amp twistlock to 30amp Rv? How?
 > Converting 30amp twistlock to 30amp Rv? How?
tealboy
orlando, fl
Posted: 09/12/17 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 30 foot 10/3 cord that has a 3 prong twist lock male that goes to my Yamaha ef2800i generator and a female that plugs into a transfer switch in my garage for storm related backup power. However, the 2800 is proving marginal, struggling to power up the 10,000 btu ac and the small 6 gallon 110 volt water heater so I want to use my two Honda eu2000s in series but the Honda with the Transgen adaptor takes a 30 amp RV plug, not a twist lock.
What is the best way to convert my male twist lock to a 30 amp rv plug? I would like to preserve option of both so cutting off and putting a new rv plug is less appealing. Is there an adaptor plug u recommend or something else easy ? We were hit by Irma and trying to make this happen soon, no power to 6 million people
ScottG
Bothell Wa.
Posted: 09/12/17 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
If I understand right, I think this will solve your problem.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
GordonThree
Northern Michigan
Posted: 09/12/17 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
I bought an short adapter cord, twist lock on one side, rv 3 way female on the other from a popular online shopping site. I believe I've seen them at a popular physical retailer as well.
Running electric water heater on generator is going to consume most of the power even from twin 2000w Honda (4kw peak, 3.2kw continous) WH probably wants 2.4kw... you won't be able to run AC and WH at the same time.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
tealboy
orlando, fl
Posted: 09/12/17 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Scott, yes, that is what I need, converting male twist to male rv. Are you or anyone aware of why this won't work for what I described?
ScottG
Bothell Wa.
Posted: 09/12/17 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
It will work fine - your using it for exactly what it's designed for.
NinerBikes
Somewhere camping
Posted: 09/12/17 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Run AC or water heater, probably can't run both at the same time. Take your pick.
time2roll
Posted: 09/12/17 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Put the water on propane
675w Solar pictures back up
GordonThree
Northern Michigan
Posted: 09/12/17 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
x2
El Pueblo Señora la Reina de los Ángeles
Posted: 09/12/17 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Only twelve bucks too, Scott.
2015 Winnebago 2101DS TT & Chevy Tahoe LTZ, 300 watts WindyNation solar - parallel & MPPT, Trojan T-125s. TALL flagpole for USC & historical flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county campgrounds. 14 year Army vet. Bicyclist!
tealboy
orlando, fl
Posted: 09/12/17 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Water heater is not problem, uses 1500 watts and only takes 45 min to make it very hot. Good for 3 moderately quick showers. I don't leave it on, no need to.
