RV.Net Open Roads Forum: Tech Issues: Converting 30amp twistlock to 30amp Rv? How?
 > Converting 30amp twistlock to 30amp Rv? How?
time2roll
Posted: 09/12/17 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
tealboy wrote:
the 2800 is proving marginal, struggling to power up the 10,000 btu ac and the small 6 gallon 110 volt water heater
[emoticon]
675w Solar pictures back up
pianotuna
Regina, SK, Canada
Posted: 09/12/17 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
I do heat my water with the air running, but I "cheat" and use load support with the Magnum inverter/charger. Generator is the Yamaha 3000 iSEB.
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
Wherever I happen to park
Posted: 09/13/17 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Standard Generator to RV power adapter sounds like what you need Get it at most any RV store or Generator store
Home is where I park it.
tealboy
orlando, fl
Posted: 09/13/17 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
[emoticon]
Fair point, I am not running them both st the same time, that would certainly be way too much. The struggles related to the ac was bc I was feeding house, then power strip then extension cord during hurricane power outage. Ran extension cord direct to ac and it ran fine on eco mode. Hot water heater problem was bc I inadvertently had large wine cooler connected to gen in addition to water heater. Usually, just the water heater by itself for 30-45 min works great. It draws somewhere close to 2000 watts
