RV.Net Open Roads Forum: Tech Issues: Will Honda 2000 supply MSH 3012's charger?
 > Will Honda 2000 supply MSH 3012's charger?
Page of 6
MrWizard
Traveling
Posted: 09/13/17 12:54am Link  |  Quote  |  Print  |  Notify Moderator
i think there is a little confusion
PT or one of the other magnum ownwers can correct me
but i think IF you set the shore power at 15a or any given amount
the magnum monitors the loads on the pass thru
if you turn something on, it will reduce the amount of charging power used
to keep total power within the the limit you set
but it is NOT an automatic 5amps of 120v use, that would only be a 600w aka 45amp charger
and that is NOT how it works
Radiate The Happy
1997 F53 Bounder 36s
outwestbound
US
Posted: 09/13/17 06:47am Link  |  Quote  |  Print  |  Notify Moderator
deleted
* This post was edited 09/13/17 10:39am by outwestbound *
2011 F350 6.7L, 4WD, DRW, 8' bed, Reese Elite 25K
2011 Carri-Lite 36XTRM5, MOR/ryde IS, 8K disc brakes, 17.5" wheels/G114s
Solar: 960 watts, 3,000 hybrid inverter, 830 AH bank, 2 controllers
IT: weboost 4G-X, WiFi Ranger Elite Pack
GordonThree
Northern Michigan
Posted: 09/13/17 10:11am Link  |  Quote  |  Print  |  Notify Moderator
That's how mine works. The charger will use as many AC amps that are available, staying under the limit.
Hybrids might be a little different?
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
outwestbound
US
Posted: 09/13/17 10:58am Link  |  Quote  |  Print  |  Notify Moderator
this is how I understand the hybrid to function. if it's detects a load while on 15amp shore setting and charging, like for AC for example, the "shore max" setting will cause a reduction of charge function and instead allocate to the load. if the load exceeds 15amps, then it will kill the charge and combine the 15amps from shore with whatever needs to be inverted from the batteries to service the AC load (called Load Support ACC on my panel, which will not allow more draw from the AC source than its set to). when the AC load terminates or drops, it will resume charging, allocating the 15amps, less any residual loads. it works in parallel to incoming loads. it does monitor the AC flowing through it, to the extent that flow is fed by the inverter (sub panel)
I can plug into a 30amp pedestal, then turn on the AC unit, and it will pull 30 on the pedestal and invert the balance to run the AC. when I turn off the AC, the charger becomes active and fills the batteries, with whatever is left over after servicing a load, if any.
lots of variability with the hybrid
I read the manual yesterday and will look again, but I think this is correct.
pianotuna
Regina, SK, Canada
Posted: 09/13/17 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Hi outwestbound,
Yes, your interpretation of the manual is correct. I don't have a sub panel--I power the entire rv via the Magnum. I can wire around it if need be. The Magnum doesn't like most GFCI outlets, hence the need to "bypass" it.
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
pianotuna
Regina, SK, Canada
Posted: 09/13/17 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
Gordon Three,
The only difference with the hybrid units is the ability to draw energy from the battery bank to make up for power over loads. The feature is called load support (but it is NOT voltage support).
BFL13
Victoria, BC
Posted: 09/13/17 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
It will take longer to get from what you started at to what stopped at for SOC. Nobody goes over 90% SOC on generator (as was mentioned several times).
You need to figure out your scenario that gets you shore power long enough, often enough, between sessions off-grid, to get to 100% and so to keep going some more off-grid. Or park in never-ending sunshine.
Oops this may be in the wrong thread.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
outwestbound
US
Posted: 09/14/17 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all for your help!! I did not know how to use my generator properly in conjunction with my solar and now I do.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 09/14/17 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Just a note - When a single battery droops down to 8 amperes charge acceptance...
Four batteries will be accepting 32 amps
Yes it is a compromise
But no denying a stored ampere hour is a stored ampere hour
outwestbound
US
Posted: 09/14/17 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
I don't understand what you mean?
Page of 6
