RV.Net Open Roads Forum: Tech Issues: Extending 10/3 gen cable?
 > Extending 10/3 gen cable?
tealboy
orlando, fl
Posted: 09/12/17 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
I made my 10/3 cable too short at 25 feet, need 35 feet. Neighbor gave me 20 feet of 10/3 so wondering if it is ok to splice in 10-15 feet and if so, what tips do u have for making a good quality splice that will hold up. Only running up to 4000 watts.
ScottG
Bothell Wa.
Posted: 09/12/17 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, it will be fine.
Now I know some will say you need 0000 or something but in the real world, you will be OK.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
Ranger Smith
Wherever the rig is parked
Posted: 09/12/17 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
I would get some of those splice connectors they use for submersible well pumps. I think that is about the best you can get
Where We Are Now
Amateur Radio Operator KK9W ARRL VE Flex 6300 & Maestro
Steve and Joy
2012 Winnebago Tour 42JD . . . 2014 Lincoln MKX Toad
Cooper ... The Doodle, Yogi...The Yorkie, Cookie ... The Chihuahua passed 11/30/2017
Baby and Kissie the new Chihuahuas
time2roll
Posted: 09/12/17 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Do you want a waterproof splice or just get the ends and make up an extension?
Top quality TT-30 connectors.
Heat shrink butt splice
If you splice the cord remove the RV end from the J-box and extend the tail. Don't cut the middle or the plug off. Seal it with heat shrink.
I would make an extension if temporary. Splice if long term.
Actually I would just get a longer pre-molded cord.
675w Solar pictures back up
BFL13
Victoria, BC
Posted: 09/12/17 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
I would put a male and female end on the new piece and just use it as a very long dogbone.
Time2roll beat me by a minute! He is another great mind that thinks alike though. [emoticon]
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
KD4UPL
Swoope, VA
Posted: 09/12/17 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Just splicing it in the middle isn't good practice. Just get a male and female and a make another cord. This will give you greater flexibility in total length; you'll have 3 choices: 25, 20, or 45.
#10 is only rated for 30 amps so at 120v you can only put 3,600 watts thru the cord.
theoldwizard1
SE MI
Posted: 09/12/17 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
If you are going to put a splice in the middle, it really should be in a metal handy box with a plain cover
Use Romex clamps to prevent the wire from pulling out and use some caulk to seal and holes. For good measure, run a bead of caulk around the edge of the cover before screwing it down.
pianotuna
Regina, SK, Canada
Posted: 09/12/17 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I'm in the same boat as BFL13 and time2roll. Add some male and female ends.
It isn't the watts that are important--it is the amps.
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
HTElectrical
Las Vegas
Posted: 09/13/17 12:12am Link  |  Quote  |  Print  |  Notify Moderator
You can't use Romex clamps on S/O cord. You can use these.[image]
This would be better.
Splice Kits
Product Details
2237A
MANUFACTURER: 3M
DESCRIPTION: CABLE SPLICE KIT, COLD SHRINK, PORTABLE, USE ON 4 CONDUCTOR 12-10 AWG CABLE (UP TO 0.62" CABLE DIAMETER), VOLTAGE RATING UP TO 1000 V, MAXIMUM RECOMMENDED VOLTAGE RATING 600 VOLT
KIT INCLUDES:
1 NEOPRENE, COLD SHRINK TUBE
1 NEOPRENE, FILLER
5 BUTT CONNECTORS
2 STRIPS, SEALING MASTIC
1 ABRASIVE CLOTH
1 ROLL, WHITE PLASTIC ELECTRICAL TAPE
1 INSTRUCTION SHEET
* This post was edited 09/13/17 12:21am by HTElectrical *
2007 Duramax, Cognito 7"-9" Lift,
Dusty R
Charlotte Michigan 48813
Posted: 09/13/17 06:05am Link  |  Quote  |  Print  |  Notify Moderator
Last I knew NEC does not allow cords to be spliced.
