RV.Net Open Roads Forum: Wfco amp test.. What are you pendant guys getting?
 > Wfco amp test.. What are you pendant guys getting?
Page of 15
lawrosa
Howell NJ
Posted: 10/12/17 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
Id rather retain the current converter. Its easy for me to run another wire or replace the existing.
I mean I was getting 60 amps with both wires.. measuring seperatly the wire I added had more amps running through it..like 38 amps on added wire vs 24 amps on the existing..
But I am not sure if this is a good formula but they do use this technique in the electrical world...
As I said the existing wire has a breaker and the wire I added had no breaker during my test..
As far finding a large breaker a 50 amps is the only one thats available off the shelf... ( walmart).. I think thats sufficient as they dont trip until a certain percentage..
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
time2roll
Posted: 10/12/17 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.amazon.com/Cooper-Bussmann-CB185-80-High-Amp-Breaker
If you are getting one of those self resetting automotive breakers... just stop. They are absolute junk at best and fire hazard often enough. Especially putting 60 amps through it.
675w Solar pictures back up
lawrosa
Howell NJ
Posted: 10/12/17 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
I have this that I bought for a solar project but I thought it was too many amps..
Its a 100 amp model like you show..although yours is 80 amps
https://www.walmart.com/ip/Bussmann-CB18........wl11=online&wl12=128038267&wl13=&veh=sem
time2roll
Posted: 10/12/17 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Ampacity is about 135 so no trouble with 100 amp breaker on #4 wire.
Even #6 is good for 100 amps as primary wire, not bundled, 105C insulation.
http://www.genuinedealz.com/voltage-drop-calculator
ktmrfs
Portland, Oregon
Posted: 10/12/17 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
agreed, at the very very least get one that does NOT automatically reset. why would you want a breaker that trips, resets, trips, resets and lets an overload go on.....
even better get a real breaker or a maxifuse.
best, get a breaker like in the above link.
2011 Keystone Outback 295RE
lawrosa
Howell NJ
Posted: 10/12/17 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
I think I will do the parallel. I found this that states two #6 = 1- #3..
Its crazy your calculator shows at 15 ft #6 has a 6% voltage drop @ 60 amps.
So I will do better then putting a # 4 to replace..
https://www.wirebarn.com/combined-wire-gauge-calculator_ep_42.html
BFL13
Victoria, BC
Posted: 10/12/17 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know, so am just asking---can those clamp meters measure the total amps with two wires at a time like that?
Perhaps related, is I am amazed at the 60 amps on that long a run of fairly thin wires. I couldn't get that.
But I use my Trimetric as the ammeter for what is going into the battery bank. I had a 55 amper on about 3 ft of #8 and it did about 55 amps, but was able to get 60 amps by changing to #4. 15 ft seems like it should be too far, but I am not there with my meter.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
lawrosa
Howell NJ
Posted: 10/12/17 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
It was additive of amps.. If I put the amp meter on the existing wire it was like 26 amps. The wire I added was like 36 amps..
The existing wire has that re-settable breaker. Maybe why more resistance.. Another issue with the factory wire is there is a soldered butt splice in it.. Story is factory wire was pinched in frame. Dealer cut it and did a shoddy repair. so I butt sliced and soldered.
This guy shows 200 amps through 4 wires...
https://www.youtube.com/watch?v=EYEiXy_ToT0&t=304s
time2roll
Posted: 10/12/17 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
I recommend a single wire.
lawrosa
Howell NJ
Posted: 10/12/17 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
reason?
Page of 15
