RV.Net Open Roads Forum: Wfco amp test.. What are you pendant guys getting?
 > Wfco amp test.. What are you pendant guys getting?
Page of 15
BFL13
Victoria, BC
Posted: 10/12/17 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Once you have the wiring such that the converter is maxed out, there is no point adding more wire unless you plan to swap to a higher amp converter in place. As you noted, you are getting the max amps now.
A few years ago, I decided to improve my 7355 converter (mid trailer) connection to the battery bank up front, since I could only get 25 amps or whatever at its 13.8v.
I ran a 20 ft length of copper water pipe under the trailer and wired it at each end to battery and converter to run in parallel with the frame on the neg side. Boom! Big increase in amps to battery.
Then I added a run of fat wire on the pos side in parallel with the existing pos wire. Boom some more! Using the 7355 as a power supply, not as a battery charger, I was now able to get 56 amps to the battery. Just for battery charging I was able to get more like 40 amps on that same pos and neg path instead of 25 amps. of course with that 13.8 single voltage converter, I was not able to test for amps to a battery at 14.4v.
So I am a believer in parallel DC wiring, but you can get it wrong. Eg, if one of the wires fails, the other should still have the ampacity to run the amps without melting. The one wire will have a huge voltage drop, but that is not melting. Different issue.
The idea is to have both paths in parallel take about half the amps, but they will actually do it in proportion, so you can have it where one is doing nearly all of it. In that case it might not be "worth it" to have the other one.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
time2roll
Posted: 10/12/17 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
lawrosa wrote:
time2roll wrote:
I recommend a single wire.
reason?
NEC
675w Solar pictures back up
lawrosa
Howell NJ
Posted: 10/12/17 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
interesting..Id like to discuss this..
Well what I think is if I run the other # 6 , its similar to the #6 thats there now.. The factory #6 may have more strands and thicker jacket why they look different.
Actually the #6 I have is typical 600v AC wire I assume.. Its good for 75 amps @ 194F
I believe once that goes on the breaker I have that was linked above ( 100 amp) it will have similar resistance to the factory wire..
Ummmm,,,, now that I think about it maybe I should treat them seperatly and fuse each line?
The reason is I am not an electrician. Im a plumber 35 years.. If as you say one line faults it may not trip that breaker. The wire may burn before the breaker trips.. FIRE!!!!! lol
I think I am best off putting a 40 amp breaker or 50 amp on each line...
Easy to do.... and cheaper for me as I have the wire..
If I had to buy wire to try to increase the size I dont think I would gain as much as I did when I paralleled them...
What do you think? Because the specs for the wire are as so..
Type THHN or THWN-2 conductors are primarily used in conduit and cable trays for services, feeders, and branch circuits in commercial or industrial applications as specified in the National Electric Code
When used as a type THHN conductor it is suitable for use in dry locations that are not to exceed temperatures of 90ºC
THHN copper conductors are annealed (soft) copper
Heat-, moisture-, gasoline- and oil-resistant
But what I see online it shows it makes no difference as long as it carry's the amps...
and both #6 wires will carry the amp rating of the converter if one fails...
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
time2roll
Posted: 10/12/17 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
Would you run parallel drains or supply pipes to mitigate inadequate flow?
lawrosa
Howell NJ
Posted: 10/12/17 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
The nec allows parallel wireing... Im just trying to find code on 12 volt instead of 120 v..
Plumbing is different then electric as venting is involved.
But yes if vented properly I can install two floor drains to disapate a specific gallons of water @ 2" pipe, or install one 3" floor drain...
Cydog15
Posted: 10/12/17 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
All the info and there is just nothing better than the 4655 MBA for the WcFO. Never understand any logic spending time on the original OEM. They just don't do the job like that 4655 MBA.
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 10/12/17 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
Depends entirely on personality.
Some folks despise investing a lot of time into a products that lack
Others see it as a challenge to update the product. Innovate.
One foot should end up pivoting on reality even if a project is a purely educational exercise.
lawrosa
Howell NJ
Posted: 10/12/17 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
But lets me realistic... I got my wfco into boost by adding a wire and getting 62 amps..
If I upgrade the bottom end to another model with the button, and no additional wiring, I will only get 30 amps or less as demonstrated by putting my amp probe on each wire separate..
Im all ears for better suggestions..
Cydog15
Posted: 10/12/17 11:22pm Link  |  Quote  |  Print  |  Notify Moderator
No question you can modify anything but the flickering and dimming lights deal keeps me away. Hear about it all the time. Just cheap made.
MEXICOWANDERER
Posted: 10/13/17 02:38am Link  |  Quote  |  Print  |  Notify Moderator
One of the things you can do to the Wiffie, is to lose the two main capacitors and replace them with Panasonic low ESR 105c rated units. Add a very quiet fan to move more air across the vertical inductors.
"Improving Perforance" means a marginally designed power supply is going to be even more greatly stressed. I would keep this in mind. Converter "designers" love to save money by using morphadite lower temperature crummy ESR caps and low voltage low amperage transistors and rectifiers and marginal air movement. Putting a Turbo on a Yugo may not prove to be a viable option.
Page of 15
