RV.Net Open Roads Forum: Tech Issues: Single AGM or 2 GC2???????
 > Single AGM or 2 GC2???????
DiskDoctr
PA
Posted: 10/11/17 11:04am Link  |  Quote  |  Print  |  Notify Moderator
This spring I asked similar questions and it was impressive the amount of knowledge and information shared by folks on here.
My main decision point was deciding between 2- 6v GC's or 2- 12v Group 31's.
For extended boondocking with occasional generator use to recharge, I wasn't sure if I'd need more. If I did, I could add ONE 12v (3 total), but would have to add TWO 6v (4 total).
In the end I elected to build a large battery box out of a truck tool box and use 4- 6v GC batteries, new converter, and pure sine wave inverter.
On our previous camper, we didn't boondock as much. We had the old converter and a pair of Group 31's (up from original single Group 27). They served us well.
We did upgrade all lights to LEDs, which REALLY helped.
As for the tech part of it, a lot of smart fellows on here [emoticon]
Sandia Man
Rio Rancho, NM
Posted: 10/11/17 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Personally, I would stick with the GC2 pair of 6 volt batteries with the exception that we purchased ours from Samsclub. We primarily camp without hookups and our pair of GC2 Interstates were still delivering decent power after 8 years when we traded them in for a new set from Samsclub. Just wanted a fresh set and cost was what I spend on gas for a single RV outing. We got way more than we paid for.
It does sound like you could just use a single 12 volt battery since you run your genny around the clock when off the power grid. We prefer to just have extra amphours in case we need it, although we have an onboard Onan and a Champion inverter genny, plus solar which sounds like overkill, we definitely don't want to be caught with out power since we find ourselves RVing in extreme temps from time to time.
As you noted, the way a battery is charged and maintained is of paramount importance for proper performance and extended longevity. We have a smart charging converter and our rig is always plugged in when stored at home, batteries are always fully charged and ready to go. Nothing wrong with buying a higher-end battery, but they will suffer the same outcome without proper charging and maintenance.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 10/11/17 11:19am Link  |  Quote  |  Print  |  Notify Moderator
With a limited budget there is no perfect answer for this. Choose your compromise and learn to live with it. Forgetting or not wanting to water a battery is a human and not battery fault unfortunately. I would do everything I could to make the task as least offensive as possible.
There is nothing to be done about high temperatures accelerating plate dissolving with hot acid. Thicker plates last longer - cost more. And are only available in golf cars batteries and other more expensive accumulators. An irressolvable quandary.
marcsbigfoot20b27
Phx
Posted: 10/11/17 11:51am Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
HTElectrical wrote:
what would be the the most economical, trouble free, dependable way to go?
You don't get all those in one purchase. AGMs are about as trouble-free as it gets, but they aren't considered "economical" if that means the cheapest.
marcsbigfoot20b27 wrote:
According to many, having one bad GC2 in a pair is nearly impossible. [emoticon]
It is if you take care of them properly, and don't try to get 15 years out of them. A 12v battery can suffer damage just as easily. I guess the eye roll indicates sarcasm.
Yes, [emoticon]
I should have included a [emoticon]
pianotuna
Regina, SK, Canada
Posted: 10/11/17 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
least maintenance is a single group 29 AGM with a modest solar charging system including temperature compensated voltage.
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
Wherever I happen to park
Posted: 10/11/17 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Some math
The Costco GC-2's are what about 80-100 bucks a pop 220 Amp Hours give or take a few at the 20 hour rate.
AGM's are way more expensive. Even "Blems" can be well over 150 dollars
Group 24 75 AH (Fit the same tray)
Group 27 95-100
Group 29 100-110
Group 31 130
What's more AGM's are SEALED Valve Regulated Lead Acid. Adding distilled is NOT an option Thus the total life tends to be less than with Flooded types.
I'd stick with GC-2
Home is where I park it.
HTElectrical
Las Vegas
Posted: 10/11/17 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
$184.00 for 2 GC2s. Done. Thanks for everyone's help.
2007 Duramax, Cognito 7"-9" Lift,
Atlee
Mechanicsville, VA
Posted: 10/11/17 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
And how many times has someone actually reported on here one of their 6V GC batteries died without warning?
Not saying there haven't been one, but I don't remember.
The fact remains that you are more likely to have someone rear end your trailer and total it while at a stoplight than you are to have one of two 6V GC batteries fail without warning.
HTElectrical wrote:
I thought I would get a couple opinions on which way I should go for my Battery replacement strategy this time.
A little background:
I just replaced my converter with a Progressive Dynamics Inteli-Power Converter 9200-14.8 Volt Deck Mount.
I had a pair of Costco GC2 Battts that were put into service on 2/2013, but were abused by my crappy WFCO converter. When I boondock, I always run my Honda 2000 (with 5 gal. external tank) basically 24/7 while I'm at the Dunes, and if not out in the sand I have power available at my covered parking. Trailer is always in the higher temps of west coast (Las Vegas, Desert)
Just recently one of my GC2s developed a shorted cell, so I need to either replace those with new 6V, or possibly with a single 12v AGM. Since I never really run my inverter or 12v for any length of time without plugging in what would be the the most economical, trouble free, dependable way to go?
Thanks in advance!!!!!!!
Costco GC2 batts are $86.00ea so a pair would be about $187.00.
I would go 12 volt flooded on the cheap or 12 volt AGM if you have a few bucks.
Erroll, Mary, Duffy the Dachshund (RIP)
www.thetravelingkoala.blogspot.com
2017 Jayco Jay Flight 23RB
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
And Blue Ox WDH/Sway Control
theoldwizard1
SE MI
Posted: 10/11/17 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
Dusty R wrote:
It appears that you are not running on battery very much you don't need much storage. So why have 2 batteries?
I am not a fan of the marine/dual purpose batteries. I don't think they do either job well.
Duracell (made by East Penn, sold at Sam's club) does make a 12V deep cycle golf cart battery (size GC12). Your local Sam's Club may not have it in stock, but they can get one for you. The problem is, it costs MORE than TWO GC2 which store more energy.
DiskDoctr
PA
Posted: 10/12/17 07:27am Link  |  Quote  |  Print  |  Notify Moderator
That sounds like a good choice. I'd suggest installing them and then plugging in your converter for 2-3 days before you go. Get them fully charged and ready to go.
Enjoy your trip!
