RV.Net Open Roads Forum: Tech Issues: Securing Honda 2000
 > Securing Honda 2000
Atlee
Mechanicsville, VA
Posted: 10/11/17 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
I run a cable through the Honda handles, the gas can handles, and the extended run tank and my TT bumper.
If someone absolutely has to have them, they can get them.
Erroll, Mary, Duffy the Dachshund (RIP)
www.thetravelingkoala.blogspot.com
2017 Jayco Jay Flight 23RB
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
And Blue Ox WDH/Sway Control
tealboy
orlando, fl
Posted: 10/12/17 04:38am Link  |  Quote  |  Print  |  Notify Moderator
Ok,, thank you. Sounds like I can try to get elaborate but in general, locking via a cable or chain thru the handle is the typical manner. I certainly have plenty of both. Plus, I'm not in an isolated high crime area, it is in a packed field of tailgaters, most of whom are good folks.
Atlee
Mechanicsville, VA
Posted: 10/12/17 06:21am Link  |  Quote  |  Print  |  Notify Moderator
You should be fine. That's where most of my boondocking is done,
at football tailgate weekends. And as you say, most of the time there are folks around so you don't need worry about bad guys coming around.
Lenny K
Vancouver Island or Quartzsite, Arizona
Posted: 10/12/17 10:00am Link  |  Quote  |  Print  |  Notify Moderator
As long as you secure your generator by chain or cable you should be fine.
In Quartzsite every winter numerous Honda 2000i are stolen. Every one was not secured which gives the thief a quick grab and run.
Lenny and Ros
2009 Chevrolet Silverado 3500 LTZ Duramax 4x4 CC Dually, Banks Speed Brake
2012 Montana 3400 RL 680 Watts Solar, 440 Amps of Batteries, GP-ISW2000-12 Inverter, Trimetric 2020, EMSHW50C, Sailun Tires
Dennis12
Ridgeley WV
Posted: 10/12/17 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Have your wife sit beside the Honda till you get back. Be careful if its running, make sure that the exhaust is facing away from her.
Dennis Hoppert
theoldwizard1
SE MI
Posted: 10/12/17 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
Kayteg1 wrote:
I match the holes in the tubing and in new tubing frame, I drilled big holes at the bottom and smaller to hold the bolts on upper skin.
So the only way to get in/out is metric socket.
For a few dollars, use a Torx Plus bolt. Just don't loose the socket/wrench.
joebedford
Finally back home in the north
Posted: 10/12/17 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
I'm REALLY surprised that no one suggested paining it yellow (I have a yellow generator for home backup).
RickSo
Alberta,Canada
Posted: 10/12/17 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
This may slow them down as well.
Honda security handle
Rick
2015 Volvo 730, D13, I-shift, 500/1850
2015 GMC 3500HD Denali 4x4 Dually
2012 Excel W41GKE Wild Cargo Toy Hauler
2010 BMW K1300GT / 2008 BMW R1200GS
2016 Polaris RZR 1000S
robert_at_honda
Alpharetta
Posted: 10/13/17 07:48am Link  |  Quote  |  Print  |  Notify Moderator
So I was visiting a big Honda commercial mower dealer out in CA, and they were prepping some new mowers for a client. After everything was inspected and tested, the shop guy wheeled them outside, and use a can of brown and can of black spray paint and randomly painted over all marks, stickers, taking care to not get any paint on the engine or controls. He then sprinkled loose soil, clippings, and debris which really made the mower look like absolute ****. He looked up at my shocked face and smiled, "So they don't look like Hondas, and won't get stolen off the trailer"
burningman
Seattle, WA USA
Posted: 10/13/17 09:31am Link  |  Quote  |  Print  |  Notify Moderator
The security handle plates are great. It is pretty easy to cut the plastic handle, without power tools.
The world does not know forever it was stolen, all you have to do is order new plastic case halves.
Honda sells every single part of that unit, down to the exact screws and washers.
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
This is how they should have built them!
