RV.Net Open Roads Forum: Tech Issues: Winterizing - Extreme cold winters
 > Winterizing - Extreme cold winters
swimmer_spe
Sudbury, Ontario, Canada
Posted: 10/11/17 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
So, I am ready to winterize my trailer's water system. I have a nice full brass fitting, an air compressor that can be adjusted for 30psi, and an air line.
Now, I know some of you know how to do this, but do you know how to do it for 'extreme' cold winters? We regularly get -30C(-20F) and colder.
For those who have those extreme temperatures over the winter, do you use antifreeze? How?
SoundGuy
S Ontario
Posted: 10/11/17 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
swimmer_spe wrote:
So, I am ready to winterize my trail[emoticon]er's water system. I have a nice full brass fitting, an air compressor that can be adjusted for 30psi, and an air line.
Not sure what "extreme" temperatures over the winter have to do with this? [emoticon] Freezing is freezing so any sustained temps below 0C and water is going to freeze eventually. Some gravity drain and add antifreeze, some blow only, some do both, but you'll never get agreement on which is "best". Do what suits you.
mike-s
Michigan
Posted: 10/11/17 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
Water expands when it freezes. After it's frozen, when it gets colder it contracts just like most materials. Colder than freezing doesn't make things worse.
DrewE
Vermont
Posted: 10/11/17 11:21pm Link  |  Quote  |  Print  |  Notify Moderator
As sound guy said, winterized is winterized. Here in Vermont we often have cold snaps around -20F (though it's not as cold as you are on the whole, I think). I blow the lines out with a compressor and put antifreeze down the drain traps and that's plenty sufficient; air doesn't freeze and expand.
I do, of course, also bring in any containers of water-based stuff like various cleaners or cans of food. Some of them may not actually freeze due to things dissolved in the water base depressing the freezing point, but I prefer not to find out which ones those are and which other ones do freeze the hard way.
Flapper
Minnesota
Posted: 10/12/17 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Here in Minnesota (-30!): I blow out all the lines with the compressor. Then I set the water heater valves to the by-pass position, and leave the big drain plug out for the winter. My water pump has a winterizing inlet tube and a couple of valves to change so the pump sucks from the tube rather than from the water tank. Stick the tube into a jug of antifreeze, turn on the pump, and then run all the taps, showers (in and out), low point drains, etc. until antifreeze comes out. Usually takes about a gallon and 1/2. The rest I pour into toilet and traps.
While just blowing out all the lines is probably pretty sufficient, I think this is one area where a belt and suspenders approach is warranted.
BTW - most bursting of pipes is due to air trapped between areas freezing water (or water and closed valves), not the ice itself. As the ice expands, the trapped air rises in pressure, to the point where the pipe or fittings give way.
2012 F150 Eco, 4x4, SCrew, Max Tow, HD Payload
2017 Grand Design Imagine 2670MK
DrewE
Vermont
Posted: 10/12/17 09:10am Link  |  Quote  |  Print  |  Notify Moderator
I'm no expert, but wouldn't it be more likely to be trapped liquid water than trapped air? The change in volume required to compress air to a pressure that would burst the pipe would have to be quite large; it would have to be squeezed into something like an eighth of the volume to increase the pressure from atmospheric pressure (ca. 14 psi) to 100 psi over atmospheric pressure and so apply a 100 psi force to the plumbing. (This is a pretty straightforward application of the ideal gas law.)
Liquid water, on the other hand, is essentially incompressible.
Kayteg1
California > Nevada
Posted: 10/12/17 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Compressors are inefficient.
Get shop vac and let it run for 1 or 2 hr to blow the piping dry
ScottG
Bothell Wa.
Posted: 10/12/17 09:29am Link  |  Quote  |  Print  |  Notify Moderator
Use the compressor, it will do a fine job. I've never had a freeze related problem do so.
FWIW, freezing is freezing so your standard winterizing procedure will work fine.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
time2roll
Posted: 10/12/17 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
Ever vacuum the water out?
675w Solar pictures back up
tenbear
Northern Vermont, USA
Posted: 10/12/17 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
We are in Northern Vermont and I just winterized this morning. I elected to use RV antifreeze but in the past I have used both methods, blowing the water out and using RV antifreeze. Both methods worked well.
If you unsure which method you want to use, do both. Blow out the lines, then fill the lines with antifreeze.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
