RV.Net Open Roads Forum: Tech Issues: Tankless Water Heater
 > Tankless Water Heater
tanklessreview
new york
Posted: 10/12/17 01:26am Link  |  Quote  |  Print  |  Notify Moderator
If you are planning to purchase tankless water heater tank , you must read about Tankless water heater from here. It will help you to know about which product is best suited for you. ***Link Removed***
SoundGuy
S Ontario
Posted: 10/12/17 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Now that didn't work for, did it? You ought to read the forum rules before attempting to advertise for free here on the forums. [emoticon]
Dick_B
Palos Heights, IL USA
Posted: 10/12/17 06:49am Link  |  Quote  |  Print  |  Notify Moderator
Part of the advice was good to read about tankless in this Forum by searching. IMHO unless one has a Park Model tankless is NOT the way to go....but I'm not an expert nor do I have one.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
gbopp
The Keystone State
Posted: 10/12/17 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Let's see what happens.. Not all advertisements get deleted. Same as sales ads, many do, some don't..
I guess it is how the moderator interprets the post?
To me, this one is an advertisement.
ScottG
Bothell Wa.
Posted: 10/12/17 08:58am Link  |  Quote  |  Print  |  Notify Moderator
I dont know what brand the OP was hawking but I was looking at the new Atwood unit and it looks promising. I think it's the only one that has a variable heater (16 to 50K BTU). It also has the biggest heater (according to Atwood).
Anyone looking at demand heaters should check it out.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
pconroy328
Colorado
Posted: 10/12/17 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Go to the Jayco Owners forum and you'll find scores of posts on Tankless. Most of them relevant to the Girards as that's what Jayco picked.
I'd venture a guess it's 80/20 or 70/30 against Girard tankless.
NC Roamer
Fuquay-Varina, NC
Posted: 10/12/17 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
We replaced the Girard tankless in our Greyhawk with a Suburban 6-gallon model. Jayco covered the swap as a warranty item for which we are very appreciative.
2014 Jayco Greyhawk 31FK
2007 Honda Shadow Sabre 1100cc
Almot
out there
Posted: 10/12/17 11:27pm Link  |  Quote  |  Print  |  Notify Moderator
To heck with that advertiser. Good job, moderator. I'm watching all the movies and shows on PVR only, skipping commercials, don't need this noise here either.
Please somebody explain - in a few words - what are the benefits of tankless compared to 4-6 gal heater in moderate to warm climate (always above freezing). Less water, less propane, longer/cheaper lifespan?
DrewE
Vermont
Posted: 10/13/17 07:38am Link  |  Quote  |  Print  |  Notify Moderator
None of those (well, I don't know about lifespan, but traditional water heaters have a long life if taken care of anyway). The main advantage is being able to take a long shower without running out of hot water, which really is only applicable if you're someplace with full hookups since otherwise you're just limited by the tank sizes. A second advantage I guess is not having to wait for it to warm up after it's been off before using hot water.
Proponents will claim that it uses less propane because it's not keeping some water hot all the time. In theory that could be true, but in practice any differences are negligible at best and, at least in sticks and bricks houses, offset by a tendency to use more hot water.
kedanie
Albuquerque, NM
Posted: 10/13/17 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Without fail, the loudest voices on these tankless threads are most always those who do not have one! Speculation and fear of the unknown.
Our Precisiontemp unit works great and uses much less propane than the old tank style units on previous RV's. Facts don't lie.
Keith
Keith and Gloria
2013 Tiffin Phaeton 36GH
2012 Jeep Grand Cherokee Overland
USAF 1968-1976 Vietnam Veteran
