RV.Net Open Roads Forum: Tech Issues: How long will this battery inverter run
 > How long will this battery inverter run
marcsbigfoot20b27
Phx
Posted: 10/12/17 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi marcsbigfoot,
I owned a 700 watt motormaster inverter.
I looked up Advance auto to see what they have......didnt see a 700 inverter, but just a power box inverter combo battery inverter jump box, by Canadian tire.
* This post was edited 10/12/17 09:40pm by marcsbigfoot20b27 *
Almot
out there
Posted: 10/13/17 12:06am Link  |  Quote  |  Print  |  Notify Moderator
Single 59 AH battery for offgrid camping? Man, where did you even find it that small? [emoticon]
Unless you want to run a generator all day long, - get at least a pair of 100AH 12V batteries (or a pair of 225AH 6V batts, same thing). Get a 12V fan like freestanding FanTastic. Get more efficient TV (should be under 40W, these days).
tealboy
orlando, fl
Posted: 10/13/17 04:58am Link  |  Quote  |  Print  |  Notify Moderator
As always, lots of great help from many. You were right, the amp hour rating I stated was wrong, it is 79 not 59.
It also sounds like when it comes to inverters, bigger is not necessarily better when the job is small. I have a small 140/200 peak watt that is capable of running the tv and fan, I tested it and seems to work perfectly fine and based on the above, sounds like going smaller is more efficient?
Re the 700 watt, it is owned by a buddy at work. I don't know the brand. The battery is a wet cell from advanced auto.
* This post was edited 10/13/17 06:09am by tealboy *
MrWizard
Traveling
Posted: 10/13/17 10:52am Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
time2roll wrote:
Guess? 15 amps x 6 hours = 75 amp hours. So you need 150 amp hours minimum. So 3 batteries should be enough. I throw in one more for good measure and unknown conditions.
Or bring the Honda.
Yes, but people seem to be assuming the battery will run down to 50% before the inverter shuts down, when I am wondering if the inverter will shut down right off because the inverter-battery wiring is not good enough. Or it might shut down real soon after it does run for a short time.
I am questioning how people can be assuming that without knowing the actual wiring.
I think we are all stating, what we think is the best case scenario
And that it could be worse
We don't know wire size, we don't know state of charge
We don't know if it's going to alarm in five minutes or 2 hours
We know he can't possibly get six, and most likely will would only get two or three at best
Radiate The Happy
1997 F53 Bounder 36s
Almot
out there
Posted: 10/13/17 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Possibly, but not important, in your case. The difference in overhead losses of inverter btw 700W and 140W model will be 5-10 Watts at best. This won't change the picture, you still need more batteries.
Inverter 140W continuous and 200W peak? With stated loads anywhere from 135 to 170W?
If loads are 135W - should be alright, inverter will get hot, "should" last for some time.
If loads are 170W, inverter will die "sooner". Peak 200W is meant for short time only, check the manual.
pianotuna
Regina, SK, Canada
Posted: 10/13/17 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.walmart.com/ip/Tripp-Lite-700-Watt-12V-Power-Inverter/11084218
marcsbigfoot20b27 wrote:
pianotuna wrote:
Hi marcsbigfoot,
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
marcsbigfoot20b27
Phx
Posted: 10/13/17 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah I saw that one, oddball sized inverter.
