RV.Net Open Roads Forum: Tech Issues: CPE Digital hybred model 100302
 > CPE Digital hybred model 100302
666JTK666
Bakersfield, CA
Posted: 10/12/17 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
I reciently purchased the cpe digital hybred 4000 serge / 3000 generator.
the engine is model yf172iv-331 224cc.
What I want to do is add electric start to this generator.
So my question is will the honda gx 200 electric start kit's I have seen on ebay be appropriate.
I plan on useing the battery power from my van to energize the electric start circuit.
If the GX 200 kit's are not appropriate, I would appreciate any suggestions on how to achieve my goal of adding electric start.
thank you.
El Pueblo Señora la Reina de los Ángeles
Posted: 10/12/17 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Is this the 4000 peak/3500 running model? I don't believe its an inverter and fairly noisy at 68 dba. Sure you want this one?
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
Posted: 10/12/17 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
I can't find the percent of Harmonic Distortion on your unit. Makes be nervous when its over 3% and I'm using it for my RV.
MrWizard
Traveling
Posted: 10/12/17 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
the Digital Hybred
is an open frame 'INVERTER' model
an inverter generator with out the completely enclosed noise reducing box
it is a NEW model from Champion Power Equipment
Radiate The Happy
1997 F53 Bounder 36s
Posted: 10/12/17 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you, Mr. Wizard.
666JTK666
Bakersfield, CA
Posted: 10/12/17 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Ok so your saying that the engine is not a gx copy ?
DrewE
Vermont
Posted: 10/12/17 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
I can't say for sure, but based on the parts diagram in the manual available online for the generator, I don't think you'll be able to add an electric starter. The flywheel does not appear to have ring gear teeth, as is common in many small engines, so there's no way for the starter motor crank the engine. Maybe that's just a limitation of the detail in the drawing.
At any rate, the chance of any odd starter working without at least some fabrication of brackets etc. is pretty slim indeed.
666JTK666
Bakersfield, CA
Posted: 10/12/17 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
The typical kit's on ebay for the gx 200 series engins include a flywheel with ring gear a starter motor and a keyswitch/solinoid box. they run around $90.00
The price for me is low enough that the risk of throing my money away wont hurt 2 badly if I am wrong. I realize that this is a new model from cpe I think I will call cpe and see if I can get some answers from tech support.
MrWizard
Traveling
Posted: 10/12/17 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
IDK what the engines specs are
i do know it is NEW and is an inverter model
thats all my post was referring too
it works the same as the pull start 3100i model
but with a higher rating, and NO 'sound muting enclosure'
maybe a way to provide inverter quality power with a higher power level, at a lower price point, than a 4000w "quiet sound enclosed version" ?
i haven't seen any other gas portable 4000w inverter genset
i think Honda has 6000w, with a hefty price, but is a superb genset
shastagary
minnesota
Posted: 10/12/17 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
first thing to look for is there a starter mounting housing on your engine. also look at some of the other champion generators with electric start to compare. some of those have the same size motor.
