RV.Net Open Roads Forum: Leave Unit plugged into A/C to keep battery charged?
 > Leave Unit plugged into A/C to keep battery charged?
dboliek1112
Perryville, AR & Raleigh, NC
Posted: 10/12/17 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
I apologize as I know the answer's here somewhere, I just couldn't find it. I have a 2000 Winnebago Chieftain 35U Motorhome. In order to keep batteries charged during the winter, should I keep A/C power constantly on so the converter charges? Any suggestions would be greatly appreciated.
"The only thing more expensive than education is ignorance." Benjamin Franklin
Dave and Missy Boliek
Roxeanne, Bell and MaggieMoo
2007 Saturn Aura
SidecarFlip
SE Michigan
Posted: 10/12/17 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
My unit stays shore powered all the time when not in use. I do check the water in the batteries monthly though.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
ScottG
Bothell Wa.
Posted: 10/12/17 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
It really depends on what convert/charger you have.
Dumb converter always at 13.6V = No. (or if you do leave it plugged in, check water levels often).
Smart converter = yes.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
Ron3rd
Upland, CA USA
Posted: 10/12/17 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
We're plugged in 24-7, 365 days a year. Have been for the last 13 years
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
SidecarFlip
SE Michigan
Posted: 10/12/17 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have to ask what the difference is between a 'smart' and 'dumb' converter may be.
I have a 'dumb' and cheap WFCO and have never has an issue. Not to say I won't, but in 2 years, no.
DutchmenSport
Between Anderson, Pendleton, & Lapel, Indiana
Posted: 10/12/17 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Think about this? You plug in your camper when you are camping. Not uncommon to have it plugged in while camping for a couple weeks at a time, or even longer. Plug it in at home for several days in a row, or whatever. What's the difference between leaving it plugged in 2 weeks, or all the time?
I park mine at home. It's been plugged in constantly since we purchased it. The only time it's not plugged into shore power is when we are on the road traveling.
Yes, check the water level in your battery occasionally. My last camper, in 8 years, replaced the battery in year 5 of ownership. NEVER added water. It never needed it.
Current camper, bought new, 4 years of ownership now. Added water once, last Fall. Levels still good. Plugged into shore power 24x7x365.
But, we do use the camper at home an awful lot. The question is, "not" how many nights have you slept in your camper this year? The question is, How many nights have you NOT slept in it this year. Answer .... maybe 28 the entire year. (The month of February when it wasn't feasible to heat it in the winter.)
Edit:
Now, if you are not using the camper at all over the winter months, then it makes more sense to pull the battery from the trailer, shut the trailer down, take the battery off, and just keep a battery tender plug in inside your garage or somewhere out of the way.
DutchmenSport
2013 Outback 298RE
2014 Chevy Silverado 3500 Duramax Dually
1400 / 14000 Equal-i-zer Weight Distribution
2 Dachshunds, 1 cat, 2 old folks and lots of love!
dboliek1112
Posted: 10/12/17 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Also we just put new AGM batteries in.
SidecarFlip
SE Michigan
Posted: 10/12/17 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
I use mine all winter actually. I's my 'break room' in the shop. A place to have hot coffee and a couple microwaved pop tarts for lunch. Love those strawberry frosted ones....
Thinking about it, I'm just like you, always plugged in except when going down the road.
pianotuna
Regina, SK, Canada
Posted: 10/12/17 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Since the jars are sealed it behooves you to follow the recommendations of the particular battery maker. Some converters may destroy AGM batteries.
The colder it is the lower the self discharge rate (it is already lower than flooded with AGM chemistries). I would fully charge the bank, and then disconnect the batteries. In three months I MIGHT do a refresher charge.
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
ScottG
Bothell Wa.
Posted: 10/12/17 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Smart charger varies voltage. Dumb charger always sits at 13.6V and will eventually boil them dry.
Lost a 1 year old battery on a dumb charger before replacing both.
Your WFCO may indeed be a smart charger - many are. Their problem is they dont go into bulk mode soemtimes.
