RV.Net Open Roads Forum: Tech Issues: LP PRESSURE ?
 > LP PRESSURE ?
Oasisbob
Portland Oregon 97266
Posted: 10/12/17 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
Recently noticed the high output burner on my stove is a tad loud and there is a section of openings that do not light on the burner. This moves if I gently blow on them. Also oven pilot has phases where it kinda burps. I replaced my LP pressure regulator five years ago. Could this be a pressure problem? How would I check the regulated pressure? What should it be?
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS">
Old-Biscuit
Verde Valley
Posted: 10/12/17 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
When was last time you CLEANED burners....toothpick openings to clear them and clean out burner gas tube
RV LP Pressure is 11" WC (that is roughly 0.4 psi)
A Manometer is used to measure pressure.....connected to gas appliance and then at least 50% of propane appliances in service
How is Water Heater Flame?
The Furnace?
Fridge?
OTHER stove top burners?
Could be dirty stove top burner, could be range/oven regulator or could be LP Reg (IF other appliances have issues)
jplante4
Cape Cod
Posted: 10/12/17 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds more like air in the line.
You need to make a manometer. Basically it's a clear tube at least 30 inches long that you fill part way with water. Make the tube into a loop, remove a burner and slip one end over the spud. Turn on the gas, the water level should move about 11 inches up the tube.
Making a manometer
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed
2014 Equinox AWD / Blue Ox
jplante4
Cape Cod
Posted: 10/12/17 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
OB - a couple of old Nukes with a brain full of worthless info lol
Old-Biscuit
Verde Valley
Posted: 10/12/17 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
And just think of all that school time/qual time spent [emoticon]
mike-s
Michigan
Posted: 10/12/17 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
Pay attention and you may learn something.
A manometer isn't anything more than some vinyl tubing from the hardware store, some water, and some knowledge (which can be easily found on the Internet). For <$5, one can eliminate (or identify) a common cause of problems with propane appliances.
Old-Biscuit
Verde Valley
Posted: 10/12/17 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
Picture and How to link too much for you grasp [emoticon]
mike-s
Michigan
Posted: 10/12/17 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
Please speak in complete English sentences if you want a meaningful response.
Almot
out there
Posted: 10/12/17 11:52pm Link  |  Quote  |  Print  |  Notify Moderator
A word to the wise is enough. And so is a sentence with minor flaw/typo (missing verb). There was, indeed, a link and "how to" picture [emoticon]...
Cleaning - Mex here knows a lot about cr-ap that propane holds and leaves in everything that it runs through. Should be stopped right at the tank, with filter. Though I doubt this was the cause of the OP issues.
dougrainer
Carrolton, Texas
Posted: 10/13/17 05:44am Link  |  Quote  |  Print  |  Notify Moderator
RV LP Stoves/ranges have their OWN LP regulator that drops the operating pressure from 11.5 to 10 inches. Odds are the burner/orifice/pilot is dirty after 17 years. Doug
 > LP PRESSURE ?
