RV.Net Open Roads Forum: Fifth-Wheels: Motorcycle on 5ver.
 > Motorcycle on 5ver.
Page of 10
4x4ord
Canada
Posted: 11/04/17 07:15am Link  |  Quote  |  Print  |  Notify Moderator
Anybody tried carrying an 800 lb motorcycle on the back of their 5ver? How did it work? I am wanting to build a hydraulic lift for mine
2017 F350 SRW Platinum short box 4x4.
B&W Companion
BarneyS
S.E. Lower Michigan
Posted: 11/04/17 07:21am Link  |  Quote  |  Print  |  Notify Moderator
The ones I have seen all had the trailer frame reinforced for quite a ways forward. Please do a lot of research before building your own. There are commercial ones available that you could probably study.
Example
Another example
Barney
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
donn0128
Pronounced Ore-gun
Posted: 11/04/17 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Thats an awful lot of weight to drop so far behind the axles. Will definitely unload your pin. After having my bicycle rack break on a rough road, I would not consider it.
Don,Lorri,and Charlie Bear 2016
8 years OSP Camp Host
The Other Dallas
azrving
Oatman
Posted: 11/04/17 07:41am Link  |  Quote  |  Print  |  Notify Moderator
800 lb plus the mechanism to lift it? You need one of those caster wheel totes and good reinforcement or double tow a trailer for the bike.
MFL
Midwest
Posted: 11/04/17 07:53am Link  |  Quote  |  Print  |  Notify Moderator
This has been discussed a lot, most don't think it is a good idea, especially for a bike that heavy. I have a factory receiver on mine, heavy 4" square tubing to frame. It's still just rated for 300 lbs, I think because of being so far behind axles, rather than strength limitation. I have a nice aluminum rack to haul my 230 lb offroad bike, but IMO, cannot be safely strapped on back of FW. Also sticker on ramp reads "not for use on back of RV trailer".
For 800 lbs you'd be best off with frame attached wheeled trailer.
Jerry
Bipeflier
Centralia, MO
Posted: 11/04/17 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Cheaper and MUCH safer to just trade for a toy hauler IMHO.
2010 Cruiser CF30SK Patriot
2016 3500 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
R12RTee
Full Timing with a home base in FL
Posted: 11/04/17 08:11am Link  |  Quote  |  Print  |  Notify Moderator
I have the HydraLift on my fiver carrying a 700 lb. bike.
I had a third axle installed to shorten the distance from the wheels to the rear of the camper and to carry the excess weight. The camper frame is 15 inches of 2x6 square tubing with sidewalls of 1/4". Most campers will not be able to support a lift and bike on the rear without modifications.
2013 DRV 38TKSB3 Mobile Suite
4x4ord
Canada
Posted: 11/04/17 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Photo bucket no longer allows 3rd party posting of photos with their free account. I'd be interested in seeing your pictures but you'd have to use this Link to post them.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 11/04/17 08:32am Link  |  Quote  |  Print  |  Notify Moderator
Mor/ryde makes a hydraulic lift and I asked them once about putting on a 5er and they didn't recommend doing it.
Now if you have a Tag Axle MH, that's a different story.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
4x4ord
Canada
Posted: 11/04/17 08:45am Link  |  Quote  |  Print  |  Notify Moderator
If only BC would allow double towing.
Page of 10
