RV.Net Open Roads Forum: Truck Campers: Another condensation ?
 > Another condensation ?
Posted: 12/16/17 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
Common issue with TCs in general.
One thing that helps is change your sleeping orientation to feet forward. Your feet don't produce near the condensation as your mouth while sleeping.
rutzbeck
Haines, AK
Posted: 12/16/17 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem in my Bigfoot when I sealed the vents. It kept in the warm air but also the moisture. I now almost always have the vents open at least 1 inch. After my shower in the morning I run the exhaust fan for at least 30 with the heater on with the vents opened even more. Hot air seems to carry out more of the moisture. A fan up at the head of the bed helps a lot also.
RickW
Sacramento CA
Posted: 12/16/17 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
As others have noted, moisture from respiration (or cooking and propane appliances) plus cold surfaces with lack of circulation equals condensation.
I built a small air to air heat exchanger (described somewhere in the archives here) to remove moist air and bring in drier air. Basically it has 2 small 12 volt fans, one to bring air in and one to exhaust air out. I have had very little condensation and no condensation problems when using it.
More importantly here, I use a 1-1/4 inch plastic bilge hose to direct the fresh air where I want it. I found I want it near the head of the bed. We are talking about a very small flow rate, maybe 1-5 CFM, that makes all the difference. The hose is easily run alomg the edge of the mattress.
In my opinion, a small forced ventilation system directed to the nose area will improve your situation.
Rick
04 GMC 1500 4X4X4
04 Sunlite SB
coolmom42
Middle Tennessee
Posted: 12/16/17 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
The material that goes under the mattress is called HyVent. It is a firm material that resembles many layers of nylon mesh. Highly recommended for use on any platform bed in a poorly insulated area. Otherwise, moisture from your bodies and breathing will penetrate the mattress and condense under it, resulting in mold growth.
2006 Toyota Sienna
Single empty-nester in Middle TN
free radical
Canada
Posted: 12/16/17 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Something like this?
https://www.defender.com/product.jsp?path=-1%257C2276179%257C2276186&id=1818021
billyray50
North Dallas
Posted: 12/17/17 06:50am Link  |  Quote  |  Print  |  Notify Moderator
It is called Hypervent and it is pricy. I purchased a product few years back for a previous TC called Dry mesh that worked good but forgot to remove it when TC was sold. It was much cheaper than Hypervent. Cannot find a U.S. distributor now. I use blue or pink foam board that's works good too for around 10.00 bucks at Lowes.
SideHillSoup
South Eastern British Columbia
Posted: 12/17/17 08:20am Link  |  Quote  |  Print  |  Notify Moderator
That is the stuff we have under our mattress and that Northern Lite now puts under the mattress in their new rigs.
Soup.
2018 Northern Lite 8-11 EX Dry Bath
2017 Sierra SLE, 3500 HD / 4x4 / Duramax with a 6 speed Allison Trans
Torklift Super Hitch 20K, 48" Super Truss, front and rear frame mounted tie downs
Fast Gun Long Range SS Turnbuckles, Fast Gun locks
RamblinAnne
California
Posted: 12/17/17 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
Soup.
x2 - I have had this hypervent under my mattress since day 1 and never had any issues with condensation. (I full time and cook often).
2013 Ford F350 6.7L Powerstroke Diesel DRW Lariat Crew Cab 4x4
2004 Bigfoot 25c10.6e
Full-timer
markchengr
Seattle
Posted: 12/18/17 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2008 Northern Lite. Initially we had the condensation problem under the mattress in cold weather. Bought some Hypervent online, laid it under the bed so that a bit of it curled up vertically along the head end and no more problem. It was pricey but in my opinion it was money well spent. -Mark.
Wardster
Kingston, Ohio
Posted: 12/19/17 05:27am Link  |  Quote  |  Print  |  Notify Moderator
Install Hypervent under your mattress to resolve the issue
2016 Northern Lite 8'11" Q Classic Special Edition
2003 GMC 2500HD Crew Cab 4x4 - Duramax/Allison
