RV.Net Open Roads Forum: Newbie travel trailer buyer question - to slide out or not
 > Newbie travel trailer buyer question - to slide out or not
Page of 13
DiskDoctr
PA
Posted: 01/18/18 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
On our Keystone Cougar, we gently use the slides on a limited basis if all the way in or all the way out- Being careful not to step on the inside edge, or within...6-10" (whatever a big step is [emoticon] )
All the way in, the slide supported against the outside of the walls of the camper. All the way out, supported against the inside of the walls of the camper and the edge against the floor.
Now that is if we must. In all reality...now that we upgraded to the 4 GC batteries, I just find a spot wide enough and zip it out and back in when finished, say for a lunch stop in a rest area or fill stop.
Battery *should* recharge along the tow. I have the charging relay and such...but I should actually test that sometime.
That is all. Back to your regularly schedule program [emoticon]
drsteve
Michigan
Posted: 01/18/18 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
During the PDI for the TT in my sig, the RV tech did say that it was a bad idea to step on the edge of the slide floor when in the retracted position. The owner's manual is silent on this issue.
1991 Palomino Filly PUP
hvac
Michigan
Posted: 01/19/18 05:08am Link  |  Quote  |  Print  |  Notify Moderator
Hey, this is all a first world problem and I see all the advantages. But, we use our coach with extensive and hard miles nationally. Our old infrastructure is challenging to any vehicle, much less a home on wheels. We often stay in casino and roadside rest stops enroute to our destination,
Just these past 2 weeks. Arcata to Needles back to Sacramento. Lots of hwy 99. The full air suspension on our truck and torsion suspension on the coach got a real workout.Made the east coast look like a glass hwy.I just can't see slides for us ever. Not after this design. We walk in, push the genny button, always set up and most important no surprises.
Each his own. I say less is more.
Sanjeev
28075
Posted: 03/07/18 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Final Update - I ended up buying the Shasta Oasis 25RS (the one with the slide out). On with learning more about the Lippert Schwintek slideout mechanism :-).
Thanks all for the vigorous debate and all the ideas and suggestions!
gmw photos
midwest
Posted: 03/07/18 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Congrats ! Now go have some fun..... don't forget the fixins' for s'mores.
DiskDoctr
PA
Posted: 03/07/18 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
Congratulations! Sounds like you worked out what was important to you and then went and snatched one up. Enjoy [emoticon]
gmw photos
midwest
Posted: 03/08/18 05:14am Link  |  Quote  |  Print  |  Notify Moderator
There are several good videos on the slide mech. Do a search for it and check out the factory videos. And get yourself a spray can of CRC power lube with teflon. It's what the factory reccos for lubing the gibs.
Main thing about Schwinteks is when running them in or out, don't stop part way. Hold the button until they run to the end of travel, then continue holding the button for a second. This will ensure the two motors are in sync with each other.
Sanjeev
28075
Posted: 03/08/18 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
good tip, thanks!
funny you say that, I saw exactly that on a video yesterday [emoticon]
Page of 13
