Sam Spade
North Central Florida
Been getting the "down for maintenance" message when trying to connect for about 5 days now.
Clearing the cookies did not help. (That was suggested by the "help desk".)
Then while poking around I remembered that there was an occasional problem for folks not using a secure connection (https: ).....and sure enough, that was my problem.
So, the complaint IS:
If this has been a known problem for a LONG time now, why does the failure message that is returned NOT mention that as something the end user should check ??
And it seems like in the past when that happened....the site refusing non-secure connections....something was done at the server end to "fix" it. Is that not going to be done anymore ??
If not, it is even more important to give back a useful failure message......or some people might just give up and never come back.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
Sam Spade
Hello Admins.
Are you reading this ??
Do you care ???
2oldman
Pahrump
Few glitches ever get fixed. This is by far the buggiest site on the entire world wide web.
Sam Spade
2oldman wrote: Few glitches ever get fixed. This is by far the buggiest site on the entire world wide web.
One doesn't have to be a "programmer" to find a text error message and EDIT IT so that it doesn't LIE to the users.
Sam Spade
BUMP. Still no reply.
If y'all think I will eventually just give up and go away......you are wrong.
Sam Spade wrote: Been getting the "down for maintenance" message when trying to connect for about 5 days now.
dedmiston
Valencia
Sam Spade wrote: BUMP. Still no reply.
If not, it is even more important to give back a useful failure message...... or some people might just give up and never come back.
Well, which one is it?
Sam Spade
Both.
One is a long time user complaining about something that isn't working right and not getting a hint of an answer.
The other is a new user trying to get connected.
I would think that the maintenance "team" would be concerned about both. Apparently not.
Sam Spade
BUMP AGAIN. It has been almost a month now and it is STILL BROKEN. It even fails and gives the WRONG FAILURE MESSAGE from the link on YOUR OWN WEBSITE. This is pretty pathetic, don't you think ??
STBRetired
I-80 and I-55
One would hope the Admins would do a simple redirect on the HTTP page to send the user to the HTTPS page.
See this link:Setting up a redirect
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy
centerline
Salem OR
please help! I am hoping to get in touch with a site administrator....
the "new thread" icon has disappeared from my screen... I can post in someone elses thread, but I have no way of posting a "new thread" of my own....
hopefully someone can forward a name of an administrator so than I cam PM them and explain the problem thanks
2007 M-3705 SLC weekend warrior, 5th wheel
2014 Ram 3500 CC/LB, 6.7 Cummins
2004 Polaris Sportsman 700
2005 Polaris Sportsman 500 HO
1979 Bayliner 2556 FB Convertible Cruiser
Heavy Equipment Repair & Specialty Welding...
