RV.Net Open Roads Forum: Travel Trailers: poor frame design on travel trailer
 > poor frame design on travel trailer
Page of 5
trailernovice
Mission TX
Posted: 01/07/18 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
On our Crossroads Z1 252BH (year 2016), the a-frame/coupler is mounted underneath the main frame rails of the trailer, rather than butted up to the main frame rails...this configuration results in the coupler sitting about 8 inches lower than it would had the a-frame continued at the same level as the main rails...
What this causes is that the rig bottoms out on even mild bumps and inclines...the w/d bars scrape, the chains hit the roadway (causing the breakaway cable intertwined with the safety chain to scrape), and the umbilical scrapes...so far I've had to replace the umbilical and the breakaway once, and they both again need replacement...at some point I'll need to replace the w/d bars...
This issue never crossed my mind when I selected this unit...should've realized the issue before purchase...
Want to take a long road trip to the West this summer, but may actually not go unless I trade this unit...went to Big Bend last summer and even that amount of 'up the hill/down the hill' had everything bottoming out a lot.
Just passing this on for what it's worth
Glenn and Toni
2016 Crossroads Z1 252BH
2016 Ram 1500 5.7 3.21 gears
Reese round bar w/d with sway control
Retired JSO
Northeast Florida
Posted: 01/07/18 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
A good trailer shop can cut off the old coupler and replace with a top mount flush fit a frame coupler in about an hour and for around $250 tops.
Old-Biscuit
Verde Valley
Posted: 01/07/18 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
With that type of A-frame/trailer frame I would be more concerned with 'failure'
kcfissel
Greenville, SC
Posted: 01/07/18 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
The trick to rewelding the a-frame to the trailer frame differently is to have a seriously qualified welder do the job. One that can weld and who understands how steel and connections work. It can be done, and done properly, and well.
I would use lots of reinforcing plates across the seams.
Ken
“needs” and “wants” are pesky things to distinguish, and the bigger the peskier…
campigloo
Baton Rouge, La
Posted: 01/07/18 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Camco (Eaz-Lift) makes a wd hitch that has the bars coming out of the top of the ball mount instead of the bottom to increase clearance. Might be worth a try.
SidecarFlip
SE Michigan
Posted: 01/07/18 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Saw that and tight away thought of Lippert components.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Vvvv1010
San Antonio, Texas
Posted: 01/07/18 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried raising the hitch head one or two holes on the shank?.....and / or maybe a set of air bags on your Ram just enough to take the edge off.
2011 Jayco Jay Flight G2 32BHDS
2011 Ford F250 6.7L Turbo Diesel
Two 10'0 Kayaks
TurnThePage
North ID
Posted: 01/07/18 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds to me like the entire trailer probably sits pretty low, exacerbated by the low-slung tongue. Maybe you should consider flipping the axles and adjusting the hitch placement.
On edit, I looked at them. They don't look like they sit that low, except maybe the tongue. Maybe you should check into a different hitch configuration like another poster mentioned.
I could even see air bags on the truck making a difference for those times when you are maneuvering driveways, etc.
* This post was edited 01/07/18 06:22pm by TurnThePage *
2015 Ram 1500
2004 Pioneer 18T6
mountainkowboy
Socal > NE Oregon
Posted: 01/07/18 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
Lippert builds ****, I've seen 12 year olds that can weld better than them.
Chuck & Ruth with 4-legged Molly
1990 F350 S/C Lariat Dually (Red)
1990 S&S 11SC Cabover
11 Ford Ranger
goducks10
There
Posted: 01/07/18 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe this would help.
https://www.reesehitches.com/products/RV........KW_uLu3mEcAMzv_mA0zMU6Sm5gkaAoYrEALw_wcB
Page of 5
