RV.Net Open Roads Forum: Tow Vehicles: Well, today it happened!! ~Updated~
Search only in Tow Vehicles
 > Well, today it happened!! ~Updated~
Page of 18
~DJ~
Boise, Idaho
Posted: 01/11/18 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Driving down the freeway got the message for low fuel pressure. Few seconds later in to limp mode. Barely got off the freeway safely. AAA towed my truck to the Dealer. My HPFP grenaded at 9300 miles!! Took the injectors with it along with a myriad of other junk. And I do mean JUNK. 2016 Suer Duty with 9300 miles!!! Run nothing but Chevron diesel from a high volume station.
I'm done!! Back to gas!! Don't care if I only climb the mtns at 45 MPH!!! [emoticon][emoticon][emoticon]
* This post was edited 01/13/18 02:57pm by ~DJ~ *
'16 FORD F250 6.7 373 FX4 Lifted with 35" Toyos Air Bags
'16 Arctic Fox 25R. Xantrex 2000 inverter/charger, four Trojan 6 volts, 450 watts solar.
DiskDoctr
PA
Posted: 01/11/18 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
What kind of additive for anti-gel did you use? If none, that can damage your pump
1320Fastback
Vista, Ca
Posted: 01/11/18 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
I love old iron but this is one of the reasons i refuse to buy a new truck.
Sorry for your loss.
1992 D250 Cummins, 5spd, 4"' straight piped, sensors deleted, airbags, DAP injectors, 18cm.
ShinerBock
SATX
Posted: 01/11/18 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry to hear that man.
BTW, not all diesels are the same in regards to injection pumps. Some use more reliable pumps than others and they will not grenade when/if they fail.
LIKE2BUILD
Decatur
Posted: 01/11/18 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
Wow man, really sorry to hear about that. Seems like there are still some problems with the Bosch CP4 HPFP. Hopefully your dealer stands behind everything and doesn't try to hide behind 'contaminated fuel' and tell you it's your problem.
I'm still running all OEM fuel and emissions systems on my RAM 6.7L. So far no major issues and hope none come. I think I'm glad I have the Bosch CP3 in my truck. Not that I can't have problems, but it sure seems like these CP4 grenades are a nightmare.
KJ
2012 Sandpiper 32QBBS
'14 Ram 2500 | Crew Cab Long Bed| 4X4 | Cummins TurboDiesel
Curt Q20 with Ram 5th Wheel Prep
2000 Crownline 205BR
1997 Ranger Comanche 461VS
'96 Polaris SLT780 PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (18, 11, & 10)
1 forgiving wife!!!
~DJ~
Boise, Idaho
Posted: 01/11/18 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Ford. Right from the Dealer.
ShinerBock
SATX
Posted: 01/11/18 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
KJ
Yeah the two piston CP4 pumps out higher max pressures than the three piston CP3 found in the Cummins 6.7L with less volume for lubrication. Not a good combo with ULSD.
blofgren
Surrey, B.C.
Posted: 01/11/18 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
I'm really sorry as well to hear this. Be sure to stay in close contact with the dealer to help ensure that it will be covered under warranty. Please keep us posted.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
DSteiner51
Wooster, Oh
Posted: 01/12/18 03:00am Link  |  Quote  |  Print  |  Notify Moderator
30 years ago we used 19,000psi water to cut 3/8 thick steel in potentially explosive environments and went thru nozzles, and now we use 28,000psi for fuel injection. When diesels went to high pressure common rail is when I decided no more diesels. Fuel mileage is no better then what we got back in the ‘80’s without such high priced systems. Went from every engine a diesel except the string trimmer to no more diesel except one older compact diesel tractor still using older tech.
Sorry for your luck but I’m not surprised. I’m more surprised that the problem is not more common.
D. Steiner
The sooner I fall behind, the more time I have to catch up.
IdaD
Idaho
Posted: 01/12/18 07:12am Link  |  Quote  |  Print  |  Notify Moderator
That surprises me - I thought the CP4 had been revised and improved from the version used in the earlier Powerstrokes? Hope you get it fixed under warranty ASAP.
2015 Cummins Ram 4wd CC/SB
Page of 18
