RV.Net Open Roads Forum: Tow Vehicles: Truck Prices & Mileage
Search only in Tow Vehicles
 > Truck Prices & Mileage
Page of 5
rollindowntheroad
Schenectady, NY
Posted: 01/12/18 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Starting to look at used trucks in order to pull a 5th wheel (don't have the 5th wheel yet). Will be looking at used, gas, 3/4 ton. I have never owned a truck before. I live in upstate NY. I can't believe the prices for trucks. And then there's the mileage on them. A couple I have seen were 2 to 3 years old and they had 50,000 to 80,000 miles on them.
Is this typical for a truck to have that many miles on them?
Death Valley!
Posted: 01/12/18 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
First rule is buy or select the 5th wheel/TT first, then match a TV to it.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
DutchmenSport
Over There
Posted: 01/12/18 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
It all depends upon what the previous owner used the truck for that's determined the mileage. That's why diesels are really a good value. At 100,000 miles, they are JUST getting broken in. 100,000 miles on a gasoline engine, and they are ready for an over-haul.
About the cost of a used truck? Consider new costs between $50,000 and $80,000, the used price is going to be steep too on any age truck.
wowens79
Georgia
Posted: 01/12/18 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
Had a friend just sell a 2015 Chevy 2500 with 115,000 miles on it. He runs all over the southeast to call on customers.
Crazy thing is it was a fully optioned diesel, and he sold it for $38,000.
2002 Chevy Silverado 1500HD 6.0l 213k miles and climbing
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
ppine
Northern Nevada
Posted: 01/12/18 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
Trucks are used a lot like cars by most people. They commute to work, they go to town. But some people haul stuff for a living. I would not buy a truck with high mileage nor one with a fifth wheel that looks like it has been used to pull with for a living.
1stgenfarmboy
Southern tip of ILL
Posted: 01/12/18 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe back in the 60's, todays gas engine will go 3-400k just like a diesel, the only difference is they cost alot less to fix when something bad goes wrong.
1993 Dodge W350 Cummins with all the goodies
2014 Ram 1500 Laramie Longhorn 2wd 395hp
2017 Forest River Surveyor 243 RBS
2001 Super Sherpa & 2012 DL650A go along also
troubledwaters
Potomac
Posted: 01/12/18 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
X2 - My 16 year old V10 gasser has 180,000 miles on it and still going strong. The body, upholstery and appurtenances will wear out long before the engine on any truck will (assuming proper maintenance is done).
OP - not all trucks will have high miles on them. So I suspect that it's the filter your using ($) weeding out the lower mileage trucks. If you want a low mileage truck, you gotta pay up. According to NADA, Even my 16 Year old truck is worth more then I would want to pay to replace it in kind.
* This post was edited 01/12/18 01:11pm by troubledwaters *
Jayco-noslide
Galesburg,Il., USA
Posted: 01/12/18 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
I don't own or need a truck so this is just a comment. I know diesels are supposed to last longer. But is the rest of the truck besides the motor really any different or better. Hundreds of non-motor parts can fail? Also, gas motors don't really wear out much now anyway do they?
Jayco-noslide
Second Chance
Wherever...
Posted: 01/12/18 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
You/we need to know some details about the fifth wheel you plan on buying before you decide on a truck - especially if you're looking at 3/4-ton trucks. Most 3/4-ton trucks will hit the limit on payload/rear axle capacity long before max towing capacity. Search for and read the threads on this or other forums about weights and capacities for towing fifth wheels. Later model trucks have higher ratings but, in short, you'll need to stick with a fifth wheel around 10,000 lbs. GVWR or less to be comfortable with the pin weight on a 3/4-ton truck... especially if you buy an older truck. There's not much price difference between a 3/4-ton and similarly equipped 1-ton truck of the same age and mileage.
Rob
U.S. Army retired
2016 Grand Design Reflection 337RLS
MOR/ryde independent suspension, disc brakes, LR G tires
PullRite OE 18K, Demco Glide Ride pin box
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
GordonThree
Northern Michigan
Posted: 01/12/18 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
I don't own Diesel so this is just observation; do a Google search on hpfp grenade
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
Page of 5
