RV.Net Open Roads Forum: 2018 Arctic Fox 865LB or Northern Lite 9-6QSE
 > 2018 Arctic Fox 865LB or Northern Lite 9-6QSE
Rustofer
Vancouver Island
Posted: 01/12/18 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
In that case, we can heartily recommend NL. We've had it only 11 months, but had it on and off the truck about a dozen times, without any hint of a structural or water-leak issue. Having said that, I'd be surprised to hear of issues in any new-ish camper. Best of luck with your quest!
Crazy Creek
Posted: 01/13/18 06:14am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2013 AF 865. Other than a few minor things it has been a good unit.
We love the layout...I have no use for a slide.
The biggest problem (we solved it) is that the fresh water pick up is at the front of a long tank. If you are parked on the slightest hill you run out of "available" water quickly.
Oh...and this is a big deal....the roof material is ****. If you back under a tree it doesn't take much for a low hanging (small) branch to poke holes in the roof material.
Mike
work2much
Jackson Ca
Posted: 01/13/18 08:40am Link  |  Quote  |  Print  |  Notify Moderator
I have owned both a bigfoot which appears at a distance to be the same clamshells that NL uses. I really liked the bigfoot camper quality. I have heard many good things about NL here and elsewhere.It was just too small for our taste with 2 dogs.
Later we purchased an Arctic Fox TC and was pleased with it at first. The owner of the company Ron Nash went out of his way to take care of some early issues we had in particular with the slide. Ron is no longer at the helm and our most recent dealings with AF (still with the slide) led me to sell it and replace it with a different brand that seems more customer service oriented.
Personally, I will not be revisiting any Northwoods products down the road.
2017 Ram 3500 Laramie DRW Crew 4x4 Aisin 4:10 Air ride.
2018 Host Mammoth. 1080 Watts solar. 600 AH usable battery. Magnum 2800 Watt inverter.
TxGearhead
Posted: 01/13/18 09:06am Link  |  Quote  |  Print  |  Notify Moderator
I really like the fiberglass clamshell construction of my Bigfoot and Northern Lite. I don't want a slide. I definitely don't want a rubber roof.
Between your 2 choices, most definitely NL.
Do the math on weights.
2016 Ram 3500 CC LB SRW Cummins Aisin Laramie Pearl White
2014 Montana High Country 305RL
2008 Bigfoot 25C9.4
motodog
Reno
Posted: 01/13/18 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys, really appreciate the informative post!
