RV.Net Open Roads Forum: Technology Corner: Batwing antenna and SensarPro
 > Batwing antenna and SensarPro
Belgique
Hickory, NC
Posted: 01/13/18 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
I've never really tried OTA since we use the TravLer in this new to us rig. I bought a SensarPro to have OTA as a back up. I can confirm that I am using the coax from the batwing to the sensar. I have direct hooked up the TV(s) from the Sensar. No splitters etc.
The Sensar finds 5 or 6 stations with a signal strength in the 60s. That tells me that the batwing and Sensar are functioning. BUT, neither TV finds any stations on a scan for ether TV or DTV. I know how to do it. It scans and says it couldn't find anything. I tried it on the main TV with a short coax. I tried it on the bedroom TV with a longer piece of coax direct from the Sensar to the TV.
What am I missing? Thanks in advance.
Hickory, NC
2007 Fleetwood Discovery 40X
enblethen
Moses Lake, WA
Posted: 01/13/18 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
First check for a small button on a wall plate for powering the amplifier in the antenna head. Power it on.
Next go to your TV menu. Look for input and set to antenna, not cable. Rerun station scan.
This should work, but check your TV owner's manual
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Belgique
Hickory, NC
Posted: 01/13/18 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Bud but I had done these
enblethen
Moses Lake, WA
Posted: 01/13/18 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried rotating the antenna? Guess which way OTA transmitter is.
rrupert
NW PA
Posted: 01/13/18 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
You may be getting a signal but it may not be strong enough to provide a functional picture. One of the drawbacks of DTV, unlike analog TV.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
enblethen
Moses Lake, WA
Posted: 01/13/18 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
No offense, but have followed the instructions?
Manual
Does your antenna head have an amplifier?
Belgique
Hickory, NC
Posted: 01/13/18 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
No offense taken. Sometimes the simplest thing is the culprit. Read the manuals for Cesar and tv. Mystery to me is that the sesar is finding signals in the 60s but not the tv.
enblethen
Moses Lake, WA
Posted: 01/13/18 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Double check your cable connections.
Make sure the LED for antenna is lit.
enblethen
Moses Lake, WA
Posted: 01/13/18 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Test the "antenna in" port for 12 volts DC to antenna head.
Then go to roof and verify it is getting to the head.
Wherever I happen to park
Posted: 01/13/18 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
60 is about the minimum usable signal
using the Sensar Pro turn to PEAK one of the signals. Then go down to the "Gain" setting (i think that is the next to the bottom LED) and up it to 20
10 is about the same as not using the Sensar Pro
See if that helps. I've been using a Sensar pro for a few years Very happy with it.
Home is where I park it.
