RV.Net Open Roads Forum: Tech Issues: Transfer switch
 > Transfer switch
Slownsy
Posted: 01/29/18 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
It already has a step up and down transformer for the 220V but as it is 50hz it will not activate inverter. So only want to be able to run with 110V 60hz generator or or of batteries. The drawing I supplied will this work ?or can someone please supply one that would without back feeding in to inverter. The power coming to junction box or toway switch will always be 110V only differens is 50-60hz.
Thanks Frank.
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 01/29/18 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Slownsy
Posted: 01/31/18 05:33am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the drawing MEXICOWANDERER, but it was more of a drawing of the supply to from and around the inverter with out having any back feed to it I was thinking about, and maybe a manual switch rather than automatically.
Thanks Frank.
Slownsy
Posted: 03/08/18 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Op date on my drawing and installation of transfer switches, has now been done by a qualified electrician and work perfectly, now I can be connected to 240V on one setting and al work in FW or other setting for running of the 12V of the inverter. I am still not very impressed by lack of support or offer of help from Magnum as regarding their so-called specifications that input 50-70Hz which they say it was never intended to work on.
Frank.
 > Transfer switch
