RV.Net Open Roads Forum: General RVing Issues: 30 AMP Connection at home
 > 30 AMP Connection at home
Page of 9
Colorado #5
Minnesota
Posted: 02/07/18 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
The owner's manual says that you need a 30amp connection in order to run the AC.
Does this mean I would need to wire my house with a 30amp receptacle in order to operate the AC while prepping and loading the coach?
mikim
Rancho Cucamonga, CA USA
Posted: 02/07/18 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
To run the A/C and not do damage to it, yes put in a 30amp outlet near the RV.
ScottG
Bothell Wa.
Posted: 02/07/18 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
A 20A, as most garages have, will power AC fine.
Even 15A will do fine as long as there aren't other loads or a voltage drop.
If you have anything less than a 30A, monitor the voltage.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
BB_TX
McKinney, Texas
Posted: 02/07/18 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
I can run my 15k A/C on a 20 amp circuit with no problem as long as I don’t run much else. It will trip a 15 amp circuit. If you only want to run it for a short period, an existing 20 amp outlet (if you have one available) should be ok.
Colorado #5
Minnesota
Posted: 02/07/18 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys.
jerryjay11
Dover
Posted: 02/07/18 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
No it does not hurt the AC or your camper. It will limit what else you use on that same circuit so expect the CB to trip during heavy load starts. I had in the past ran my AC in our camper from a standard 20 amp circuit for several years before installing a 30 camper outlet last year. I'd forget about it and load up the same circuit with my table saw when the CB would trip. Just don't use an extension cord unless it is the same size wiring as the camper. I've used a 100 foot extension I made up and had no problem where I couldn't get closer to the outlet when visiting my brother.
If you want to use it for any length of time other than prep you'd be better off adding a 120 volt, 30 amp circuit with out door outlet.
STBRetired
I-80 and I-55
Posted: 02/07/18 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
Before I put in my 50A receptacle, I would run one of my 13.5K A/C units on a 20A circuit. I needed to use a 10GA extension cord to avoid excessive voltage drop.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy
time2roll
Posted: 02/07/18 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Just be sure it is only 120 volts. Fairly common for an electrician or a buddy to wire this outlet (NEMA 30-TT) with 240 volts. Single breaker with single hot, neutral, ground.
Measure voltage before you plug in. Have the electrician show you on his meter.
675w Solar pictures back up
ktmrfs
Portland, Oregon
Posted: 02/07/18 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
well, the AC draws at most 13A, so running on a 20A breaker is fine. 15A, pushing the limit. myself and many many others have run the AC on 20A breakers either at home or in a park with only 20A circuits.
Now, if you also want to run other accy in the trailer as well, then you may need a 30A circuit.
2011 Keystone Outback 295RE
InspectorMark
Michigan
If you want to run your ac off a 20amp circuit you better have the shortest, highest amp extension cord possible. Best would be to plug your camper plug directly into a garage plug with the proper adapter.
Mark Mustola
Linden, Michigan
Page of 9
