RV.Net Open Roads Forum: Tech Issues: Another AGM conditioning question
 > Another AGM conditioning question
Page of 12
Naio
Snug as a bug in a rug
Posted: 03/06/18 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
It never got 24 hours. Maybe 1 hour total, in bits and pieces. Lotta dial twiddling and grabs for the off switch each time it got to 30 amps.
I was actually encouraged that it got to 6 volts, but I am quite ignorant...
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 03/06/18 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
I followed the confusing twiddles and grabs and came up for air and read it differently...[emoticon]
Allow it to charge but halt charging if it exceeds 30 amps
OR
You can set voltage limit back to 13.2
Charge until amperage reads 20 or less
Tweak voltage back up to 14.4 then charge until amperage drops to 1.0 or less.
You have to periodically check battery temp with your hand. Stop if one or more cells gets quite warm to the hand.
Naio
Posted: 03/06/18 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
Glad to hear there may still be hope!
But how low a voltage can the MW put out?
This battery won't take 13v.
Even with the MW at 12.36v, amps still kept going up albeit more slowly, about 1a per 30 seconds or so.
So I got in maybe 5 mins of charging before it hit 30 amps. But that 5 mins took me up to 6v [emoticon].
I am not sure if the Megawatt goes much lower?
Also I gotta do this on a dry day, as there is no roof [emoticon] and I have to sit there staring at the ammeter.
* This post was edited 03/06/18 11:16pm by Naio *
time2roll
Posted: 03/06/18 11:23pm Link  |  Quote  |  Print  |  Notify Moderator
Megawatt does not seem like a good solution if it does not self limit the amps at the max rating. Or are you adjusting the voltage while connected? Set at just 1 volt over the battery voltage. Increase 1 volt when amps are steady or dropping.
Do you have a different charger or some jumper cables? Standard converter would be better. If you can jump the battery to get the automatic charger started I think you could leave it charge overnight in a safe place.
675w Solar pictures back up
Naio
Posted: 03/06/18 11:27pm Link  |  Quote  |  Print  |  Notify Moderator
My smart charger wouldn't recognise the battery at 1v, altho now that it is up to 6v I could try again.
You think jumper cables and a running engine? Lord knows this battery would leap at the chance to gorge on 100 amps, but I am not sure it wouldn't eat itself to death.
Naio
Posted: 03/06/18 11:30pm Link  |  Quote  |  Print  |  Notify Moderator
On the low amp end, I have 3 dashboard solar trickle chargers I could put on it.
I know AGM's don't usually like a trickle charge, but I'm wondering if that might be ok in this situation? They put out about 14.45 volts, I think.
Naio
Posted: 03/07/18 12:15am Link  |  Quote  |  Print  |  Notify Moderator
Googling, I see the mw can go as low as 10 volts. I could try that [emoticon]
MEXICOWANDERER
Posted: 03/07/18 12:22am Link  |  Quote  |  Print  |  Notify Moderator
turn anticlockwise do not force plastic screw
MEXICOWANDERER
Posted: 03/07/18 12:23am Link  |  Quote  |  Print  |  Notify Moderator
Naio
Posted: 03/07/18 12:27am Link  |  Quote  |  Print  |  Notify Moderator
Ok. Is the solar trickle charge an ok option, too?
As for the jumper cables, I do not think I know anyone with a big enough rig to turn over my big van engine. Am not at an rv park.
Page of 12
