RV.Net Open Roads Forum: Towing: Need assistance with identification...
Search only in Towing
Open Roads Forum  >  Towing
 > Need assistance with identification...
harperscott
Washington State
Posted: 02/12/18 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Bought a used f350 about a year ago and have been unable to find anyone who can tell me what type of hitch, or who made, or anything about the under-bed rail system that was already in the truck when I purchased it - it is not your typical rail system as it is not a rectangle - the rear holes (connections) are narrower than the front - If anyone know who this is made by (no marks on it) OR what type hitch hooks into it, I would be greatly appreciative!!
Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
* This post was edited 02/12/18 06:13pm by an administrator/moderator *
lawrosa
Horry County
Posted: 02/12/18 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
Boy thats a tough one.. I read references of it online but could not find any facts/solutions. Factory ford???
Whats year of truck?
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
LIKE2BUILD
Decatur
Posted: 02/12/18 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
Definitely need to know the year of the truck. Newer Fords (2014+ I think) had the option of factory rail systems that are under the bed.
Take a look at the video for B&W Companion Hitch install for Ford Factory Rails. Based not that video, it doesn't seem like the pucks you have match the OEM kit.
The way the front and rear connections are offset and the direction of the slots makes me think it could be a PullRite Under Bed Connection System. IF that's correct, you'd need the PullRite Superglide 5th wheel hitch to mate up with that system.
Take a look at these Ford Under Bed Kit installation instructions and see if the recommended measurements match up with the hole locations in your bed.
KJ
2012 Sandpiper 32QBBS
'14 Ram 2500 | Crew Cab Long Bed| 4X4 | Cummins TurboDiesel
Curt Q20 with Ram 5th Wheel Prep
2000 Crownline 205BR
1997 Ranger Comanche 461VS
'96 Polaris SLT780 PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (18, 11, & 10)
1 forgiving wife!!!
lawrosa
Horry County
Posted: 02/12/18 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
KJ
Isnt that odd though that its to the rear of the truck? In reference to the gooseneck cut out and the four other points.
As you see in the pic the proper points are there but around the center of the gooseneck cut out...
Slownsy
Posted: 02/12/18 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
It is a pullrite under bead brackets for the superglide hitch nothing unusual about it.
Frank.
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
LIKE2BUILD
Decatur
Posted: 02/13/18 07:09am Link  |  Quote  |  Print  |  Notify Moderator
I kind thought the placement was strange. I would have thought it wound be centered over the axle. But if it’s a super glide it will need support in the rear position too.
DSteiner51
Wooster, Oh
Posted: 02/13/18 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Frank.
Yep, Pullrite Superglide.
D. Steiner
The sooner I fall behind, the more time I have to catch up.
Slownsy
Posted: 02/13/18 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
The pin is centered or in front of axle, I have got this hitch, if you' look at your brackets you will se that rear of hitch is supported on the chassis.
harperscott
Washington State
Posted: 02/14/18 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
the truck is a 2013 - and I'll take measurements to compare with the Superrail mounting kit BUT that looks to be it // THANK YOU ALL!!! I am not sure why no one could tell me this until now // I even sent pictures and description to eTrailer.com guys and they had no idea (guess that should tell me something :-) THANKS THANKS THANKS!!! After I compare measurements, I'll let every one know. APPRECIATED!
mkirsch
Rochester, NY
Posted: 02/14/18 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
To be fair, etrailer.com doesn't appear to sell Pullrite, so they wouldn't recognize it.
