RV.Net Open Roads Forum: Tech Issues: I did it again....
 > I did it again....
dtappy3353
Oregon
Posted: 02/13/18 09:53am Link  |  Quote  |  Print  |  Notify Moderator
Had 1500w inverter installed.
When inverter is turned on, exterior marker lights flicker. Unable to see the flickering during day and just discovered a couple nights ago.
Am puzzled as to what is wrong.
Any thoughts?
2oldman
Salton Sea
Posted: 02/13/18 09:58am Link  |  Quote  |  Print  |  Notify Moderator
What's the condition of your batteries? What does the subject line mean?
BFL13
Victoria, BC
Posted: 02/13/18 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Are the marker lights LEDs?
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
dtappy3353
Oregon
Posted: 02/13/18 10:16am Link  |  Quote  |  Print  |  Notify Moderator
batteries are full and marker lights LEDs.
Subject line means DIY projects always with issues...wish I knew more but am trying.
SoundGuy
S Ontario
Posted: 02/13/18 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Any thoughts?
Would have to be a ground issue as that's the only commonality between the trailer's marker lights and the rest of it's 12 vdc system.
GordonThree
Northern Michigan
Posted: 02/13/18 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a poorly designed input stage on the inverter. What brand and model?
How are you turning the marker lights on?
Do the interior lights "flicker" as well?
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 02/13/18 11:03am Link  |  Quote  |  Print  |  Notify Moderator
For simplicity...
Connect a 100uf 30 volt electrolytic capacitor across the 12 volt power to the trailer lights. Be sure the cap has a good path to chassis negative.
Radio shack would have something that would work. Doesn't have to be 100 microfarad -- 20 to 470 would work just as well.
jkwilson
Indiana
Posted: 02/13/18 11:24am Link  |  Quote  |  Print  |  Notify Moderator
What kind of RV are we talking about here?
If it's a trailer, I'd try turning the marker lights on with a fuse in the plug to help narrow down the issue.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
dtappy3353
Oregon
Posted: 02/13/18 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Fifth wheel. Marker lights are the only ones that lightly flicker when inverter is on. Trailer is parked in our back yard. Were hoping to go boondocking soon.
Are we talking battery ground cause the tester did not show open ground on the 110v side.
Interior lights do not flicker at all.
Pure Sine Wave Power Inverter 1500w Eco-Worthy
BFL13
Victoria, BC
Posted: 02/13/18 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
So how do you get the marker lights to go on? One way is to shove a bent out paper clip into the 7-pin.
