RV.Net Open Roads Forum: Travel Trailers: tires
skinnyme
Pa
Posted: 02/14/18 07:50am Link  |  Quote  |  Print  |  Notify Moderator
Is it ok to run P rated tires on the front of my ram 1500 while running E rated tires on the rear. I'm towing a 6200 lb. travel trailer. Thank you.
proxim2020
Houston
Posted: 02/14/18 08:34am Link  |  Quote  |  Print  |  Notify Moderator
What are you trying to accomplish? You would be mixing tires with different load capacities, inflation requirements, and handling characteristics which isn't a good idea. Also you would be limited on positions where the tires could be rotated to. Once the WDH moves weight forward, you'll end up with a bouncy/squishy front end and a solid rear. You'd be better off going with LTs all around.
WNYBob
Tonawanda, NY
Posted: 02/14/18 08:45am Link  |  Quote  |  Print  |  Notify Moderator
Here are my two cents worth. P tires have softer sidewalls and therefore more flex than the E tires. This means that the front end can and will move sideways easier and more, not good when towing!
time2roll
Posted: 02/14/18 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Are you spending money? Are you just getting two LTs for the rear? s/b fine however when the Ps are done, square it away with LT on the front also.
I would not go much above 50 psi on the LT-E used on a 1500.
675w Solar pictures back up
donn0128
Pronounced Ore-gun
Posted: 02/14/18 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Scary handling comes to mind. DO NOT DO IT!
Don,Lorri,and Charlie Bear 2016
8 years OSP Camp Host
The Other Dallas
rbpru
North Central Indiana
Posted: 02/14/18 10:13am Link  |  Quote  |  Print  |  Notify Moderator
I suppose you can run any combination you want but the function of the WD hitch is to transfer some of the tongue weight to the front axle and tires so the TV and TT sit level. Usually that means the same tires all around.
In my case I have had excellent results with the original P tires over the last 30,000 miles of towing. So when it came time to replacing them, I decided not to fix what was not broke. The TV was designed for P tires, so I run P tires.
I do bump the air pressure up to 40 lbs. when I tow. But the DW already thinks The TV rides like a buck board farm wagon, so I certainly am not going to do anything to stiffen the ride.
Some folks feel better with LT's or some other premium tire, so there is no reason for them not to use what they like.
Good Luck
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
2012Coleman
Posted: 02/14/18 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Why - to save money?
Experience without good judgment is worthless; good judgment without experience is still good judgment!
sneakygroundbuzzard
st cloud mn
Posted: 02/14/18 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
i worked as an auto tech for 25 years
every shop i worked in(including dealerships) sold tires
never a good idea to mix tires on anything
this goes for make.modle and size of tires
also a good idea to make sure tires on all axles have near the smae amount of tread
most people dont realize that tires are part of your suspension and braking systems,but they are
falconbrother
North Carolina
Posted: 02/14/18 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Just get a full set of tires. When I bought my old motorhome it had a set of no-name Chinese tires on it. Of course I had a massive blowout on a 10 lane section of highway in the evening rush hour. I literally thought my wife had a heart attack. It cost me $2700.00 bucks for a brand new set of tires that evening but, I was happy to pay it. What seems expensive now seems cheap when bad things happen.
My point is get a set of tires, all the same, equal to the task, and of good reputation. Never skimp on tires related to RV-ing.
JIMNLIN
Oklahoma
Posted: 02/14/18 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
Good grief...folks have ran P tires on front and LT on the rear even when all tires were bias ply. Radials are no different. Now mixing bias and radials can create dangerous handling issues.
The P tire in front and LT on the rear will not create any issues if you run the P tires at max 44 or 51 psi which ever the case......and run the LT on the rear at 50-55 psi which is about all many 1/2 ton wheels are rated for.
I've used all season Passengers on the front and bigger/same size LT all terrain type tires on the rear on every 1/2 ton truck I've owned for winter use. No issues.
You may have to jocky PSI a bit find a psi best suited for intended use.
